Using framework 60W power adapter to connect to a power bank a bad idea?
Recently I’ve been looking at brands like UGREEN and INIU when it comes to power banks around 45-100W for my framework 13 amd laptop.
This made me thinking, in general powerbanks from what I know about them don’t usually come with a wall adapter in order to charge them. But would that hurt the laptop and destroy it?
Or am I better off using even a 42W Dual Port Charger Block even though USB C outlet on that is 30W while the USB A is 12?
Thanks.
The Framework power adapter are normal USB-C PD charger. You can charge your powerbank with it.
A good power bank and a good charger – and, crucially, good cables – communicate their power capacity using the USB spec and will behave within spec.
K3n.
