Currently designing a VGA expansion card. Planning on using the Cypress CCG3 for DisplayPort conversion and NXP 3392.
Should have a schematic completed soon.
Any thoughts on connector placement? If I’m not mistaken standard DB-9 would not fit, so an oversized card would probably be required.
Yes, will be oversized, VGA uses DE-15 not DB-9.
Are you getting somewhere? I’m interested too. Thinking of producing to sell or only for personnal use?
I’m interested in this project, too. I work with a lot of legacy projectors in my workplace and having an HDMI connection is more of an exception. I had to use a dongle for this.
Continuing the discussion from VGA expansion card:
I wish they make that VGA expansion card sooner?
I am working on it, but have many expansion cards that I’m working on.
What is the current status?
Is there a way to help you on the project?
Any update?
