This is an odd error in Windows 11 latest release on my Framework 16 with the 7840HS CPU, 780M iGPU, and 7700S dGPU. With HDR OFF videos and other applications appear overexposed at seemingly random times. Interestingly, I cannot capture this in a screenshot:
All I did in this example was scroll down the YouTube page slightly. This occurs even when playing videos locally in MPC and other software. Turning ON HDR fixes this problem, but I don’t want HDR on because it is limited on my external monitor and causes other problems. This also occurs on the internal screen. All FW drivers and BIOS are on the latest stable versions.
I was able to change the setting but I can’t remember what setting it is, it says something about dynamically changing the colors (I think it’s some sort of HDR alternative)
Solved this by deleting the icc profile from the monitor manufacturer and using the windows default. Wasn’t issue on my last pc but must be a windows issue.
