Virtualization on FW16's Ryzen 9 (7940HS)
One potential issue you may hit (that I didn’t see mentioned here yet) if you want to pass through the AMD graphics is that AMD’s consumer GPUs don’t support SR-IOV. This means the dGPU can only be passed through to a single VM.
Intel iGPUs (and I think Nvidia GPUs ones with a tweaked driver) support SR-IOV, which lets you use the GPU for things like hardware acclerated video encode/decode across multiple VMs (or both the VM and the host system) at the same time. I use it on my home server running Unraid, to transcode video (TV shows recorded with a HDHomeRun) in a Docker container while also using hardware accelerated transcoding in a Windows Server 2022 VM for Blue Iris (security camera software).
Ah so there is progress, looks like you’re almost there :slight_smile:
Error 43 indicates driver errors, this could be because the driver doesn’t want to play nice in a VM (NVidia is notorious for that, but hey, this is AMD, and should work better). It could also indicate that the driver is expecting a different pci bus configuration (which is more likely i think).
There’s a few more things you could try. Looking at the command-line you posted earlier, i suggest the following:
  • in the ‘-device vfio-pci,host=0000:03:00.0’ line add ‘multifunction=on’, and remove the ‘romfile=…’ option.
  • also in the ‘-device vfio-pci’ lines, you now have different bus= assignment, each with address 0x0. Instead, try having them on the same bus, but then with address 0x0.0 and address 0x0.1 respectively, that way the video and audio devices are configured as subfunctions of the same master device, just like on the host.
  • in the ‘-cpu’ line, try adding the ‘kvm=off’ flag.
Not sure how to do that in libvirt, but surely it has an option for using ‘multifunction’ devices, which is the essence here.
Good luck!
Thank you for your input!
I followed your guide, but without success. PCI-Assignments should be in order now?
I reinstalled Windows again and rebooted the host before installing the framework driver package on the VM.
One strange thing i noticed is, that I cannot reboot the VM. If I do, I loose the disyplay output. I have to shutdown the VM and then start it again in order to get display output. Rebooting with Ubuntu on the VM on the other hand works just fine.
I only use the card in one VM at a time.
Here is my current log (I removed my serial number):
2024-05-18 18:43:21.075+0000: starting up libvirt version: 8.0.0, package: 1ubuntu7.10 (Marc Deslauriers <marc.deslauriers@ubuntu.com> Fri, 12 Apr 2024 13:48:21 >
LC_ALL=C \
PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin \
HOME=/var/lib/libvirt/qemu/domain-3-ubuntu22.04 \
XDG_DATA_HOME=/var/lib/libvirt/qemu/domain-3-ubuntu22.04/.local/share \
XDG_CACHE_HOME=/var/lib/libvirt/qemu/domain-3-ubuntu22.04/.cache \
XDG_CONFIG_HOME=/var/lib/libvirt/qemu/domain-3-ubuntu22.04/.config \
/usr/bin/qemu-system-x86_64 \
-name guest=ubuntu22.04,debug-threads=on \
-S \
-object '{"qom-type":"secret","id":"masterKey0","format":"raw","file":"/var/lib/libvirt/qemu/domain-3-ubuntu22.04/master-key.aes"}' \
-blockdev '{"driver":"file","filename":"/usr/share/OVMF/OVMF_CODE.fd","node-name":"libvirt-pflash0-storage","auto-read-only":true,"discard":"unmap"}' \
-blockdev '{"node-name":"libvirt-pflash0-format","read-only":true,"driver":"raw","file":"libvirt-pflash0-storage"}' \
-blockdev '{"driver":"file","filename":"/var/lib/libvirt/qemu/nvram/Ubuntu_VARS.fd","node-name":"libvirt-pflash1-storage","auto-read-only":true,"discard":"unmap">
-blockdev '{"node-name":"libvirt-pflash1-format","read-only":false,"driver":"raw","file":"libvirt-pflash1-storage"}' \
-machine pc-q35-6.2,usb=off,vmport=off,dump-guest-core=off,pflash0=libvirt-pflash0-format,pflash1=libvirt-pflash1-format,memory-backend=pc.ram \
-accel kvm \
-cpu host,migratable=on,kvm=off \
-m 16000 \
-object '{"qom-type":"memory-backend-ram","id":"pc.ram","size":16777216000}' \
-overcommit mem-lock=off \
-smp 8,sockets=8,cores=1,threads=1 \
-uuid ................ \
-smbios 'type=0,vendor=INSYDE Corp.,version=03.03,date=03/27/2024,release=3.3' \
-smbios 'type=1,manufacturer=Framework,product=Laptop 16 (AMD Ryzen 7040 Series),version=A7,serial=FRAGACCPA740830006,sku=FRAGACCP07,family=16in Laptop' \
-smbios 'type=2,manufacturer=Framework,product=FRANMZCP07,version=A7,serial=leftout 00XS,asset=*,location=*' \
-smbios type=3,manufacturer=Framework,version=A7,serial=......,asset=...,sku=..... \ #serial left out
-smbios >
-no-user-config \
-nodefaults \
-chardev socket,id=charmonitor,fd=33,server=on,wait=off \
-mon chardev=charmonitor,id=monitor,mode=control \
-rtc base=utc,driftfix=slew \
-global kvm-pit.lost_tick_policy=delay \
-no-hpet \
-no-shutdown \
-global ICH9-LPC.disable_s3=1 \
-global ICH9-LPC.disable_s4=1 \
-boot strict=on \
-device pcie-root-port,port=8,chassis=1,id=pci.1,bus=pcie.0,multifunction=on,addr=0x1 \
-device pcie-root-port,port=9,chassis=2,id=pci.2,bus=pcie.0,addr=0x1.0x1 \
-device pcie-root-port,port=10,chassis=3,id=pci.3,bus=pcie.0,addr=0x1.0x2 \
-device pcie-root-port,port=11,chassis=4,id=pci.4,bus=pcie.0,addr=0x1.0x3 \
-device pcie-root-port,port=12,chassis=5,id=pci.5,bus=pcie.0,addr=0x1.0x4 \
-device pcie-root-port,port=13,chassis=6,id=pci.6,bus=pcie.0,addr=0x1.0x5 \
-device pcie-root-port,port=14,chassis=7,id=pci.7,bus=pcie.0,addr=0x1.0x6 \
-device pcie-root-port,port=15,chassis=8,id=pci.8,bus=pcie.0,addr=0x1.0x7 \
-device pcie-root-port,port=16,chassis=9,id=pci.9,bus=pcie.0,multifunction=on,addr=0x2 \
-device pcie-root-port,port=17,chassis=10,id=pci.10,bus=pcie.0,addr=0x2.0x1 \
-device pcie-root-port,port=18,chassis=11,id=pci.11,bus=pcie.0,addr=0x2.0x2 \
-device pcie-root-port,port=19,chassis=12,id=pci.12,bus=pcie.0,addr=0x2.0x3 \
-device pcie-root-port,port=20,chassis=13,id=pci.13,bus=pcie.0,addr=0x2.0x4 \
-device pcie-root-port,port=21,chassis=14,id=pci.14,bus=pcie.0,addr=0x2.0x5 \
-device qemu-xhci,p2=15,p3=15,id=usb,bus=pci.2,addr=0x0 \
-device virtio-scsi-pci,id=scsi0,bus=pci.5,addr=0x0 \
-device virtio-serial-pci,id=virtio-serial0,bus=pci.6,addr=0x0 \
-blockdev '{"driver":"file","filename":"/var/lib/libvirt/images/ubuntu22.04.qcow2","node-name":"libvirt-3-storage","auto-read-only":true,"discard":"unmap"}' \
-blockdev '{"node-name":"libvirt-3-format","read-only":false,"discard":"unmap","driver":"qcow2","file":"libvirt-3-storage","backing":null}' \
-device virtio-blk-pci,bus=pci.4,addr=0x0,drive=libvirt-3-format,id=virtio-disk0 \
-blockdev '{"driver":"file","filename":"/home/matthias/Schreibtisch/Win11_23H2_German_x64v2.iso","node-name":"libvirt-2-storage","auto-read-only":true,"discard":>
-blockdev '{"node-name":"libvirt-2-format","read-only":true,"driver":"raw","file":"libvirt-2-storage"}' \
-device ide-cd,bus=ide.0,drive=libvirt-2-format,id=sata0-0-0 \
-blockdev '{"driver":"file","filename":"/home/matthias/Downloads/virtio-win-0.1.240.iso","node-name":"libvirt-1-storage","auto-read-only":true,"discard":"unmap"}>
-blockdev '{"node-name":"libvirt-1-format","read-only":true,"driver":"raw","file":"libvirt-1-storage"}' \
-device ide-cd,bus=ide.1,drive=libvirt-1-format,id=sata0-0-1 \
-netdev tap,fd=34,id=hostnet0,vhost=on,vhostfd=36 \
-device virtio-net-pci,netdev=hostnet0,id=net0,mac=52:54:00:27:88:9e,bus=pci.1,addr=0x0 \
-chardev pty,id=charserial0 \
-device isa-serial,chardev=charserial0,id=serial0 \
-chardev socket,id=charchannel0,fd=31,server=on,wait=off \
-device virtserialport,bus=virtio-serial0.0,nr=1,chardev=charchannel0,id=channel0,name=org.qemu.guest_agent.0 \
-chardev spicevmc,id=charchannel1,name=vdagent \
-device virtserialport,bus=virtio-serial0.0,nr=2,chardev=charchannel1,id=channel1,name=com.redhat.spice.0 \
-device usb-tablet,id=input0,bus=usb.0,port=1 \
-audiodev '{"id":"audio1","driver":"spice"}' \
-spice port=5900,addr=127.0.0.1,disable-ticketing=on,image-compression=off,seamless-migration=on \
-device ich9-intel-hda,id=sound0,bus=pcie.0,addr=0x1b \
-device hda-duplex,id=sound0-codec0,bus=sound0.0,cad=0,audiodev=audio1 \
-chardev spicevmc,id=charredir0,name=usbredir \
-device usb-redir,chardev=charredir0,id=redir0,bus=usb.0,port=2 \
-chardev spicevmc,id=charredir1,name=usbredir \
-device usb-redir,chardev=charredir1,id=redir1,bus=usb.0,port=3 \
-device vfio-pci,host=0000:04:00.0,id=hostdev0,bootindex=1,bus=pci.9,addr=0x0 \
-device vfio-pci,host=0000:03:00.0,id=hostdev1,bus=pci.3,multifunction=on,addr=0x0 \
-device vfio-pci,host=0000:03:00.1,id=hostdev2,bus=pci.3,addr=0x0.0x1 \
-device virtio-balloon-pci,id=balloon0,bus=pci.7,addr=0x0 \
-object '{"qom-type":"rng-random","id":"objrng0","filename":"/dev/urandom"}' \
-device virtio-rng-pci,rng=objrng0,id=rng0,bus=pci.8,addr=0x0 \
-sandbox on,obsolete=deny,elevateprivileges=deny,spawn=deny,resourcecontrol=deny \
-msg timestamp=on
char device redirected to /dev/pts/0 (label charserial0)
2024-05-18T18:44:42.549183Z qemu-system-x86_64: terminating on signal 15 from pid 1553 (/usr/sbin/libvirtd)
2024-05-18 18:44:43.350+0000: shutting down, reason=destroyed
Not sure if this is the problem, but it seems you are still missing the
-vga none
-nographic
arguments in your command, meaning that qemu will still enable it’s default vga display, that could be a problem.
@CodeMichael did you ever figure out how to get dgpu to attach and detach without going unstable?
Has anyone else figured this out? It’d be awesome to be able to detach it when launching the VM to attach it to the VM, then have it reattach to the computer after the VM shuts down.
This is the script I’ve been using which seems to be stable, but I wouldn’t say I’ve gone through extensive testing either.
Does this mean the comment about instability in your repo’s main README.md is possibly no longer valid?
I haven’t used it much, but so far its been stable. I’ve been refactoring my repo after rebuilding my desktop, so I haven’t update in a bit, but I’ll correct that statement when I do get around to updating.
So… I finally got it working. What a mess.
Upgrading to Ubuntu 24.04. instantly solved all my problems. I guess the machine version 6.2 was the problem. With 24.04. I now have version 8.2.
I created a new machine and only needed the kvm=hidden tag to get it working… :smiley:
Thanks to all of you for your help.
I traveled over the holidays and was able to swap back and forth between VM and native. There did seem to be some instability, but in all honesty that might have been something else I was working on.
On another note, not particularly related to the main topic.
I recently tried out Waydroid on Linux to do some Android gaming and it’s been running great. Performance is really good and it isn’t even that power hungry.
I’m using Waydroid on NixOS with KDE.
Be aware when you do dGPU VFIO, you also lose access to /dev/kfd until next reboot.
Haven’t seen any response from AMD about that
Hey, doing the same here (except with windows 11). I’ve been running into some pretty wild artifacting - works fine with very basic uis (desktop, most web pages) but seems to run into issues when there’s a lot of layers.
Was wondering if anyone else has had this issue.
Doesn’t look like I can upload a video. The black in the background is what should be my wallpaper (windows default).
my config in virt-manager
<domain type="kvm">
  <name>win11</name>
  <uuid>fd0be41d-e6b3-42c3-b259-612043c9bcfb</uuid>
  <metadata>
    <libosinfo:libosinfo xmlns:libosinfo="http://libosinfo.org/xmlns/libvirt/domain/1.0">
      <libosinfo:os id="http://microsoft.com/win/11"/>
    </libosinfo:libosinfo>
  </metadata>
  <memory unit="KiB">31457280</memory>
  <currentMemory unit="KiB">31457280</currentMemory>
  <memoryBacking>
    <hugepages/>
  </memoryBacking>
  <vcpu placement="static">8</vcpu>
  <cputune>
    <vcpupin vcpu="0" cpuset="8"/>
    <vcpupin vcpu="1" cpuset="9"/>
    <vcpupin vcpu="2" cpuset="10"/>
    <vcpupin vcpu="3" cpuset="11"/>
    <vcpupin vcpu="4" cpuset="12"/>
    <vcpupin vcpu="5" cpuset="13"/>
    <vcpupin vcpu="6" cpuset="14"/>
    <vcpupin vcpu="7" cpuset="15"/>
  </cputune>
  <os firmware="efi">
    <type arch="x86_64" machine="pc-q35-9.1">hvm</type>
    <firmware>
      <feature enabled="no" name="enrolled-keys"/>
      <feature enabled="yes" name="secure-boot"/>
    </firmware>
    <loader readonly="yes" secure="yes" type="pflash" format="raw">/usr/share/edk2/x64/OVMF_CODE.secboot.4m.fd</loader>
    <nvram template="/usr/share/edk2/x64/OVMF_VARS.4m.fd" templateFormat="raw" format="raw">/var/lib/libvirt/qemu/nvram/win11-2_VARS.fd</nvram>
    <boot dev="hd"/>
  </os>
  <features>
    <acpi/>
    <apic/>
    <hyperv mode="custom">
      <relaxed state="on"/>
      <vapic state="on"/>
      <spinlocks state="on" retries="8191"/>
      <vendor_id state="on" value="fuckyou"/>
    </hyperv>
    <kvm>
      <hidden state="on"/>
    </kvm>
    <vmport state="off"/>
    <smm state="on"/>
  </features>
  <cpu mode="host-passthrough" check="none" migratable="on">
    <topology sockets="8" dies="1" clusters="1" cores="1" threads="1"/>
  </cpu>
  <clock offset="localtime">
    <timer name="rtc" tickpolicy="catchup"/>
    <timer name="pit" tickpolicy="delay"/>
    <timer name="hpet" present="no"/>
    <timer name="hypervclock" present="yes"/>
  </clock>
  <on_poweroff>destroy</on_poweroff>
  <on_reboot>restart</on_reboot>
  <on_crash>destroy</on_crash>
  <pm>
    <suspend-to-mem enabled="no"/>
    <suspend-to-disk enabled="no"/>
  </pm>
  <devices>
    <emulator>/usr/bin/qemu-system-x86_64</emulator>
    <disk type="file" device="disk">
      <driver name="qemu" type="qcow2"/>
      <source file="/home/wade/images/windows"/>
      <target dev="sda" bus="sata"/>
      <address type="drive" controller="0" bus="0" target="0" unit="0"/>
    </disk>
    <controller type="usb" index="0" model="qemu-xhci" ports="15">
      <address type="pci" domain="0x0000" bus="0x02" slot="0x00" function="0x0"/>
    </controller>
    <controller type="pci" index="0" model="pcie-root"/>
    <controller type="pci" index="1" model="pcie-root-port">
      <model name="pcie-root-port"/>
      <target chassis="1" port="0x10"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x0" multifunction="on"/>
    </controller>
    <controller type="pci" index="2" model="pcie-root-port">
      <target chassis="2" port="0x11"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x1"/>
    </controller>
    <controller type="pci" index="3" model="pcie-root-port">
      <target chassis="3" port="0x12"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x2"/>
    </controller>
    <controller type="pci" index="4" model="pcie-root-port">
      <target chassis="4" port="0x13"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x3"/>
    </controller>
    <controller type="pci" index="5" model="pcie-root-port">
      <target chassis="5" port="0x14"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x4"/>
    </controller>
    <controller type="pci" index="6" model="pcie-root-port">
      <target chassis="6" port="0x15"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x5"/>
    </controller>
    <controller type="pci" index="7" model="pcie-root-port">
      <target chassis="7" port="0x16"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x6"/>
    </controller>
    <controller type="pci" index="8" model="pcie-root-port">
      <target chassis="8" port="0x17"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x7"/>
    </controller>
    <controller type="pci" index="9" model="pcie-root-port">
      <target chassis="9" port="0x18"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x03" function="0x0" multifunction="on"/>
    </controller>
    <controller type="pci" index="10" model="pcie-root-port">
      <target chassis="10" port="0x19"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x03" function="0x1"/>
    </controller>
    <controller type="pci" index="11" model="pcie-root-port">
      <target chassis="11" port="0x1a"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x03" function="0x2"/>
    </controller>
    <controller type="pci" index="12" model="pcie-root-port">
      <target chassis="12" port="0x1b"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x03" function="0x3"/>
    </controller>
    <controller type="pci" index="13" model="pcie-root-port">
      <target chassis="13" port="0x1c"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x03" function="0x4"/>
    </controller>
    <controller type="pci" index="14" model="pcie-root-port">
      <target chassis="14" port="0x1d"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x03" function="0x5"/>
    </controller>
    <controller type="pci" index="15" model="pcie-root-port">
      <target chassis="15" port="0x1e"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x03" function="0x6"/>
    </controller>
    <controller type="pci" index="16" model="pcie-to-pci-bridge">
      <model name="pcie-pci-bridge"/>
      <address type="pci" domain="0x0000" bus="0x05" slot="0x00" function="0x0"/>
    </controller>
    <controller type="sata" index="0">
      <address type="pci" domain="0x0000" bus="0x00" slot="0x1f" function="0x2"/>
    </controller>
    <controller type="virtio-serial" index="0">
      <address type="pci" domain="0x0000" bus="0x03" slot="0x00" function="0x0"/>
    </controller>
    <interface type="network">
      <mac address="52:54:00:04:d7:e9"/>
      <source network="default"/>
      <model type="virtio"/>
      <address type="pci" domain="0x0000" bus="0x01" slot="0x00" function="0x0"/>
    </interface>
    <serial type="pty">
      <target type="isa-serial" port="0">
        <model name="isa-serial"/>
      </target>
    </serial>
    <console type="pty">
      <target type="serial" port="0"/>
    </console>
    <channel type="spicevmc">
      <target type="virtio" name="com.redhat.spice.0"/>
      <address type="virtio-serial" controller="0" bus="0" port="1"/>
    </channel>
    <input type="mouse" bus="ps2"/>
    <input type="keyboard" bus="ps2"/>
    <input type="mouse" bus="virtio">
      <address type="pci" domain="0x0000" bus="0x06" slot="0x00" function="0x0"/>
    </input>
    <input type="keyboard" bus="virtio">
      <address type="pci" domain="0x0000" bus="0x07" slot="0x00" function="0x0"/>
    </input>
    <graphics type="spice" autoport="yes">
      <listen type="address"/>
      <image compression="off"/>
    </graphics>
    <sound model="ich9">
      <address type="pci" domain="0x0000" bus="0x00" slot="0x1b" function="0x0"/>
    </sound>
    <audio id="1" type="spice"/>
    <video>
      <model type="none"/>
    </video>
    <hostdev mode="subsystem" type="pci" managed="yes">
      <source>
        <address domain="0x0000" bus="0x03" slot="0x00" function="0x0"/>
      </source>
      <address type="pci" domain="0x0000" bus="0x04" slot="0x00" function="0x0"/>
    </hostdev>
      <source>
        <address domain="0x0000" bus="0x03" slot="0x00" function="0x1"/>
      </source>
      <address type="pci" domain="0x0000" bus="0x08" slot="0x00" function="0x0"/>
    </hostdev>
    <hostdev mode="subsystem" type="usb" managed="yes">
      <source>
        <vendor id="0x046d"/>
        <product id="0xc091"/>
      </source>
      <address type="usb" bus="0" port="1"/>
    </hostdev>
      <source>
        <vendor id="0x04d9"/>
        <product id="0x0169"/>
      </source>
      <address type="usb" bus="0" port="4"/>
    </hostdev>
    <redirdev bus="usb" type="spicevmc">
      <address type="usb" bus="0" port="2"/>
    </redirdev>
      <address type="usb" bus="0" port="3"/>
    </redirdev>
    <watchdog model="itco" action="reset"/>
    <memballoon model="none"/>
    <shmem name="looking-glass">
      <model type="ivshmem-plain"/>
      <size unit="M">64</size>
      <address type="pci" domain="0x0000" bus="0x10" slot="0x01" function="0x0"/>
    </shmem>
  </devices>
</domain>
Nevermind! Got it working. Turns out it was a kernel bug. Switching to linux-lts from linux (arch) fixed it.
I thought I had passed through The GPU shoes up device manager and looking Glass is working but the performance is nowhere near where it should be like 727 in superposition.
<domain xmlns:qemu="http://libvirt.org/schemas/domain/qemu/1.0" type="kvm">
  <name>win11</name>
  <uuid>51bc9ca8-c610-4e77-9d40-18e55be51e1e</uuid>
  <metadata>
  </metadata>
  <memory unit="KiB">16777216</memory>
  <currentMemory unit="KiB">16777216</currentMemory>
  <memoryBacking>
    <source type="memfd"/>
    <access mode="shared"/>
  </memoryBacking>
  <vcpu placement="static">14</vcpu>
  <os firmware="efi">
    <type arch="x86_64" machine="pc-q35-10.0">hvm</type>
    <firmware>
    </firmware>
    <nvram template="/usr/share/edk2/x64/OVMF_VARS.4m.fd" templateFormat="raw" format="raw">/var/lib/libvirt/qemu/nvram/win11_VARS.fd</nvram>
    <boot dev="hd"/>
  </os>
  <features>
    <acpi/>
    <apic/>
      <vapic state="on"/>
      <vpindex state="on"/>
    </hyperv>
    <kvm>
    </kvm>
    <smm state="on"/>
  </features>
    <topology sockets="1" dies="1" clusters="1" cores="7" threads="2"/>
    <feature policy="require" name="topoext"/>
    <feature policy="require" name="svm"/>
  </cpu>
  </clock>
  <pm>
  </pm>
  <devices>
      <driver name="qemu" type="qcow2" cache="none" discard="unmap"/>
      <source file="/var/lib/libvirt/images/win11.qcow2"/>
      <target dev="vda" bus="virtio"/>
    </disk>
    </controller>
    </controller>
    </controller>
    </controller>
    </controller>
    </controller>
    </controller>
    </controller>
    </controller>
    </controller>
    </controller>
    </controller>
    </controller>
    </controller>
    </controller>
    </controller>
    </controller>
    </controller>
    </controller>
    <controller type="scsi" index="0" model="lsilogic">
    </controller>
      <mac address="52:54:00:7a:f9:3a"/>
      <link state="up"/>
    </interface>
    <serial type="pty">
      </target>
    </serial>
    </console>
    </channel>
    </input>
      <address type="pci" domain="0x0000" bus="0x09" slot="0x00" function="0x0"/>
    </input>
    <tpm model="tpm-crb">
      <backend type="emulator" version="2.0"/>
    </tpm>
    <graphics type="spice" port="-1" autoport="no" listen="127.0.0.1">
      <listen type="address" address="127.0.0.1"/>
    </graphics>
    </sound>
    <video>
      <model type="vga" vram="16384" heads="1" primary="yes"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x0"/>
    </video>
      <source>
      </source>
    </hostdev>
      <source>
      </source>
      <rom bar="off"/>
    </hostdev>
    </redirdev>
  </devices>
  <qemu:commandline>
    <qemu:arg value="-device"/>
    <qemu:arg value="{'driver':'ivshmem-plain','id':'shmem0','memdev':'looking-glass'}"/>
    <qemu:arg value="-object"/>
    <qemu:arg value="{'qom-type':'memory-backend-file','id':'looking-glass','mem-path':'/dev/kvmfr0','size':67108864,'share':true}"/>
  </qemu:commandline>
</domain>
Does anyone have any ideas?
Also, when I try and connect the dGPU to an external display from the USB port on the back via a dock that I bought a long time ago I get this weird output after the EFI Boot splash.
The screen looks familiar, I see the same thing when I boot Windows 11 in a VM with dGPU passthrough and LookingGlass. It did not used to be like that, but I don’t know what update caused it, since I don’t connect a monitor very often. When I first installed the VM it also used to be necessary to connect a dummy output plug, to get things to work, that need is also not there anymore, so some things must have been updated since I first setup this VM.
Strangely booting a Linux VM with the same dGPU passthrough settings, everything looks fine, which leads me to believe that this is likely a windows driver / looking glass related issue, but I could be mistaken.
Recently I updated looking-glass from B6 to B7 release, but that did not improve the display output.
