Washed out color when gaming
This seems to be similar to other folks’ posts, but I wanted help specific to this framework 16 laptop, AMD AI with nvidia 5070 GPU. I can tell when I run a 3d game (in this case Minecraft) the second monitor turns on. I assume that’s the outboard GPU.
But when the game starts up, the saturation is flat, like HDR is broken and off. Colors don’t pop, and it’s the opposite of pop: noticeably flat.
Anyone had that problem that fixed it? thanks!
Sounds like the gamma or contrast is set incorrectly. I’m guessing you’re seeing this issue on the second monitor. Try adjusting the monitors settings from its hardware controls. I find opening a colourful HDR image to match to helps.
Could just be your graphics settings in minecraft.
