Weird wifi issues, possibly pcie/hardware issue framework 16
[c2@cachywork ~]$ fastfetch
           .-------------------------:                    c2@cachywork
         :++===++==================-       :++-           OS: CachyOS x86_64
        :*++====+++++=============-        .==:           Host: Laptop 16 (AMD Ryzen AI 300 Series) (A9)
       -*+++=====+***++==========:                        Kernel: Linux 6.19.10-1-cachyos-bore
      =*++++========------------:                         Uptime: 2 hours, 20 mins
     =*+++++=====-                     ...                Packages: 1597 (pacman), 13 (flatpak)
   .+*+++++=-===:                    .=+++=:              Shell: bash 5.3.9
  :++++=====-==:                     -*****+              Display (Odyssey G7): 3840x2160 in 32", 165 Hz [External]
 :++========-=.                      .=+**+.              WM: Hyprland 0.54.3 (Wayland)
.+==========-.                          .                 Cursor: Adwaita
 :+++++++====-                                .--==-.     Terminal: kitty 0.46.2
  :++==========.                             :+++++++:    Terminal Font: NotoSansMono-Regular (11pt)
   .-===========.                            =*****+*+    CPU: AMD Ryzen AI 9 HX 370 (24) @ 5.16 GHz
    .-===========:                           .+*****+:    GPU 1: AMD Radeon 890M Graphics [Integrated]
      -=======++++:::::::::::::::::::::::::-:  .---:      GPU 2: NVIDIA GeForce RTX 5070 Max-Q / Mobile [Discrete]
       :======++++====+++******************=.             Memory: 23.00 GiB / 93.58 GiB (25%)
        :=====+++==========++++++++++++++*-               Swap: 0 B / 109.58 GiB (0%)
         .====++==============++++++++++*-                Disk (/): 1.23 TiB / 1.80 TiB (68%) - xfs
          .===+==================+++++++:                 Local IP (wlan0): 172.19.166.11/18
           .-=======================+++:                  Battery (FRANDBA): 99% (30 days, 17 hours, 23 mins remaining) [Discharging]
             ..........................                   Locale: en_US.UTF-8
[c2@cachywork ~]$
so i’ve been havign wifi issues with wifi discounting the reconencting, which isn’t a major issue on it’s own but my vpn requries me to manauly restart the connection every time i change networks or if internet goes out, which is happening every 2-10 minutes.
these logs in partical are what are making me think it’s a hardware issue
[c2@cachywork ~]$ sudo dmesg | grep -i “aer|pcie.*err|c0:00|mt7925.*err|link down”
[ 9.287936] pcieport 0000:00:01.1: pciehp: Slot(0): Link Down
[ 9.454538] mt7925e 0000:c0:00.0: ASIC revision: 79250000
[ 9.529929] mt7925e 0000:c0:00.0: HW/SW Version: 0x8a108a10, Build Time: 20260106153007a
[ 9.869882] mt7925e 0000:c0:00.0: WM Firmware Version: ____000000, Build Time: 20260106153120
[ 7817.160559] mt7925e 0000:c0:00.0: disabling ASPM L1
[ 7817.165201] mt7925e 0000:c0:00.0: ASIC revision: 79250000
[ 7817.242543] mt7925e 0000:c0:00.0: HW/SW Version: 0x8a108a10, Build Time: 20260106153007a
[ 7817.585164] mt7925e 0000:c0:00.0: WM Firmware Version: ____000000, Build Time: 20260106153120
[ 8012.838986] mt7925e 0000:c0:00.0: disabling ASPM L1
[ 8012.844218] mt7925e 0000:c0:00.0: ASIC revision: 79250000
[ 8012.922585] mt7925e 0000:c0:00.0: HW/SW Version: 0x8a108a10, Build Time: 20260106153007a
[ 8013.265235] mt7925e 0000:c0:00.0: WM Firmware Version: ____000000, Build Time: 20260106153120
[c2@cachywork ~]$
device (wlan0): state change: activated → unmanaged (reason ‘unmanaged-link-not-init’, managed-type: ‘removed’)
radio killswitch … rfkill1 disappeared
i got no idea why this is happening but if any one knows a fix that would be good. i can also go pretty deep into this, on my gentoo desktop i had to manualy find the kernel driver and the adress of the fan control on my asus motherboard which wasn’t fun.
i am also getting alot of journalctl errors
[c2@cachywork ~]$ journalctl -xb -p err
Mar 30 15:20:15 cachyos kernel:
Mar 30 15:20:21 cachywork systemd-udevd[828]: /etc/udev/rules.d/80-nvidia-pm.rules:3 Invalid key/value pair, ignoring.
Mar 30 15:20:21 cachywork systemd-udevd[828]: /etc/udev/rules.d/80-nvidia-pm.rules:4 Invalid key/value pair, ignoring.
Mar 30 15:20:21 cachywork systemd-udevd[828]: /etc/udev/rules.d/80-nvidia-pm.rules:8 Invalid key/value pair, ignoring.
Mar 30 15:20:21 cachywork systemd-udevd[828]: /etc/udev/rules.d/80-nvidia-pm.rules:9 Invalid key/value pair, ignoring.
Mar 30 15:20:21 cachywork systemd-udevd[828]: /etc/udev/rules.d/80-nvidia-pm.rules:13 Invalid key/value pair, ignoring.
Mar 30 15:20:21 cachywork systemd-udevd[828]: /etc/udev/rules.d/80-nvidia-pm.rules:14 Invalid key/value pair, ignoring.
Mar 30 15:20:21 cachywork systemd-udevd[828]: /etc/udev/rules.d/80-nvidia-pm.rules:18 Invalid key/value pair, ignoring.
Mar 30 15:20:21 cachywork systemd-udevd[828]: /etc/udev/rules.d/80-nvidia-pm.rules:22 Invalid key/value pair, ignoring.
Mar 30 15:20:21 cachywork systemd-udevd[828]: /etc/udev/rules.d/80-nvidia-pm.rules:26 Invalid key/value pair, ignoring.
Mar 30 15:20:22 cachywork kernel: I/O error, dev sda, sector 3888672 op 0x0:(READ) flags 0x80700 phys_seg 27 prio class 2
Mar 30 15:20:22 cachywork kernel: I/O error, dev sda, sector 3888672 op 0x0:(READ) flags 0x800000 phys_seg 1 prio class 2
Mar 30 15:20:22 cachywork kernel: Buffer I/O error on dev sda1, logical block 485828, async page read
Mar 30 15:20:22 cachywork kernel: usb 5-1.2.2.2: parse_audio_format_rates_v2v3(): unable to retrieve number of sample rates (clock 41)
Mar 30 15:20:22 cachywork systemd[1]: Failed to mount /home/c2/ssd2.
░░ Subject: A start job for unit home-c2-ssd2.mount has failed
░░ Defined-By: systemd
░░ Support: ``https://lists.freedesktop.org/mailman/listinfo/systemd-devel
░░ A start job for unit home-c2-ssd2.mount has finished with a failure.
░░ The job identifier is 181 and the job result is failed.
Mar 30 15:20:23 cachywork kernel: ucsi_acpi USBC000:00: unknown error 256
Mar 30 15:20:24 cachywork bluetoothd[1111]: Failed to set default system config for hci0
Mar 30 15:20:24 cachywork kernel: ucsi_acpi USBC000:00: unknown error 256
Mar 30 15:20:25 cachywork libvirtd[1235]: cannot open directory ‘/home/c2/ssd2/win11_vm’: No such file or directory
Mar 30 15:20:25 cachywork libvirtd[1235]: internal error: Failed to autostart storage pool ‘win11_vm’: cannot open directory ‘/home/c2/ssd2/win11_vm’: No such file or directory
Mar 30 15:24:31 cachywork kernel: usb 5-1.2.2.2: Unable to submit urb #5: -19 at snd_usb_queue_pending_output_urbs
Mar 30 15:24:31 cachywork kernel: usb 5-1.2.2.2: cannot submit urb 0, error -19: no device
Mar 30 15:24:36 cachywork kernel: ucsi_acpi USBC000:00: unknown error 0
Mar 30 15:24:36 cachywork kernel: ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-95)
Mar 30 15:30:27 cachywork systemd[1]: Failed to start Refresh arch / cachyos mirror lists.
░░ Subject: A start job for unit cachyos-rate-mirrors.service has failed
░░ A start job for unit cachyos-rate-mirrors.service has finished with a failure.
░░ The job identifier is 4740 and the job result is failed.
Mar 30 15:34:27 cachywork kactivitymanagerd[11640]: Couldn’t start kglobalaccel from org.kde.kglobalaccel.service: QDBusError(“org.freedesktop.DBus.Error.ServiceUnknown”, “The name is not activatable”)
Mar 30 15:37:40 cachywork kactivitymanagerd[11640]: “applications.menu” not found in QList(“/etc/xdg/menus”)
Mar 30 15:38:41 cachywork systemd[1]: NetworkManager-initrd.service: Two services allocated for the same bus name org.freedesktop.NetworkManager, refusing operation.
Mar 30 15:48:04 cachywork syncthing[1453]: Remote is an introducer to us, and we are to them - only one should be introducer to the other, see ``https://docs.syncthing.net/users/introducer.html`` (device=G4HJUNI log.>
Mar 30 15:49:18 cachywork kactivitymanagerd[11640]: “applications.menu” not found in QList(“/etc/xdg/menus”)
Mar 30 15:51:39 cachywork syncthing[1453]: Remote is an introducer to us, and we are to them - only one should be introducer to the other, see ``https://docs.syncthing.net/users/introducer.html`` (device=G4HJUNI log.>
Mar 30 15:57:59 cachywork syncthing[1453]: Remote is an introducer to us, and we are to them - only one should be introducer to the other, see ``https://docs.syncthing.net/users/introducer.html`` (device=G4HJUNI log.>
Mar 30 15:59:53 cachywork syncthing[1453]: Remote is an introducer to us, and we are to them - only one should be introducer to the other, see ``https://docs.syncthing.net/users/introducer.html`` (device=G4HJUNI log.>
Mar 30 16:19:52 cachywork kernel: Bluetooth: hci0: ACL packet for unknown connection handle 3837
Mar 30 16:31:33 cachywork syncthing[1453]: Remote is an introducer to us, and we are to them - only one should be introducer to the other, see ``https://docs.syncthing.net/users/introducer.html`` (device=G4HJUNI log.>
Mar 30 16:49:41 cachywork sudo[92073]: pam_unix(sudo:auth): conversation failed
Mar 30 16:49:41 cachywork sudo[92073]: pam_unix(sudo:auth): auth could not identify password for [c2]
Mar 30 17:15:05 cachywork kernel: ucsi_acpi USBC000:00: unknown error 0
Mar 30 17:15:06 cachywork kernel: ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-95)
Mar 30 17:15:13 cachywork kernel: ucsi_acpi USBC000:00: unknown error 0
Mar 30 17:15:13 cachywork kernel: ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-95)
Mar 30 17:30:29 cachywork wpa_supplicant[1228]: Could not read interface p2p-dev-wlan0 flags: No such device
Mar 30 17:33:45 cachywork wpa_supplicant[1228]: Could not read interface p2p-dev-wlan0 flags: No such device
[c2@cachywork ~]$
