What kind of panel?
I have looked around the website and cannot find out what type of panel is used for the screen. Is it IPS, VA, or TN? I need to know before I can order.
Thank you.
Framework uses a BOE CQ NE135FBM-N41 IPS panel.
I just found the following description of the display on a review site:
Display –
13.50 inch 3:2, 2256 x 1504 pixel 201 PPI, BOE CQ NE135FBM-N41, IPS, BOE095F, glossy: yes, 60 Hz
So, yes, it’s an IPS. Would have preferred a VA panel for deeper blacks but IPS is works well.
