Hello,
Which bezel and keyboard color should I pick if I want to match the color of the laptop body (which I apparently cannot pick)?
Thanks!
Hello,
Thanks!
Keyboard color?
The laptop body of the Framework 13 is aluminum (silver color), the bezels and keyboard keys are made from plastic and can’t match that. The default color is black.
For the FW13, there’s only two aesthetic options for keyboards at this time: transparent or black. If you want to match the keyboard with the chassis, you can get the transparent keyboard and pair it with the transparent or gray bezel.
