Wifi Card doesnt get detected
Hi!
I received my Framework 13 AMD edition (Ryzen 7 7840) 4 days ago. Worked completely fine since. This morning I couldnt connect to a WiFi. It looks like the WiFi card isnt detected. Restarting and a new Install of the Driver bundle didnt help.
Does anyone else has a similar issue?
Update: after a couple of restarts it magically works again. Still a very oder behaviour.
What operating system?
Windows 11 22H2.
Since it has started working magically, I would suggest checking the card connection, re-insert it. Maybe there is a poor connection. :thinking:
