Workaround: Framework 13 Pro (Intel Core Ultra Series 3) screen tearing / flicker on Arch
Scope note: this is a Linux fix. It is a kernel module parameter for the Intel xe driver and does nothing on Windows. If you are seeing similar tearing on Windows, this thread will not help you. I hand-verified this on my new motherboard after switching from an AMD Ryzen that didn’t have this problem.
I originally thought this was caused by a loose display cable, but nope.
Which Linux distro are you using? Arch Linux
Which release version? Rolling, no release version
If rolling release, last date updated? 2026-07-26
Which kernel are you using? 7.1.5-arch1-1
Which BIOS version are you using? INSYDE 03.02 (release 3.2, dated 2026-05-26)
Which Framework Laptop 13 model are you using? Intel Core Ultra Series 3 (Core Ultra X7 358H), Laptop 13 Pro, board FRANMJCP07 rev A7
Batch 1 here, running Arch. Hit this within a day of setup and it looked alarming enough that I want it written down before the rest of Batch 1 lands. Short version: it is not your panel, it is not your mainboard, and you do not need to RMA. It is Panel Self Refresh and Panel Replay on the new xe driver against this eDP panel.
Symptoms
If you are here from a search, the plain-language version: the screen tears, flickers, blinks, or flashes black on a brand new Framework Laptop 13 Pro running Linux. It looks like failing hardware. It is (probably) not.
  • Horizontal tear lines or a torn band across the screen, worst during scrolling and window drags.
  • Brief full-screen flicker, screen blinking, or a black flash when the screen content goes mostly static and then updates (notification popups, cursor blink in a terminal).
  • Compositor reports no tearing of its own. On Hyprland hyprctl monitors showed activelyTearing: false while the panel was visibly tearing, which is the giveaway that this is below the compositor.
  • Both the tearing and the flicker only occur inside a desktop environment. A pure TTY (Ctrl+Alt+F2, no compositor running) is completely clean. This is a useful first diagnostic: drop to a TTY, scroll some output, and if it looks fine there but tears under your DE, you are almost certainly looking at this bug rather than a failing panel or cable. It is also why nobody should rush to RMA over it.
Prior art, and why this is not that
“Disable PSR on a Framework” is old advice. There is a 2021 thread (Screen tearing with Linux) where the second reply is already telling people the topic is beaten. So to be clear about what is actually new here:
  • Those threads are 11th/12th/13th gen on the i915 driver. This is Panther Lake on xe. The parameter prefix changed, so i915.enable_psr=0 does nothing on this hardware. It has to be xe.enable_psr=0.
  • Most of the old tearing threads resolve to X11 compositing or fractional scaling, and the fix is “use Wayland” or “use the modesetting driver”. That is a different bug. I am already on Wayland at integer scale 1.0 and still saw this.
  • Panel Replay did not exist in those threads. It is an eDP 1.5 feature, it is a separate knob from PSR, and it is on by default here. If you carry over the old muscle memory and set only xe.enable_psr=0, you may not fix it.
That last point is the entire reason I am posting rather than pointing at the old threads.
The fix
Add these two kernel parameters:
xe.enable_psr=0 xe.enable_panel_replay=0
That is it. Reboot and it is gone.
enable_psr=0 disables Panel Self Refresh. enable_panel_replay=0 disables Panel Replay, which is the newer eDP 1.5 equivalent and is enabled by default on this hardware. I set both at the same time and the problem went away, so I cannot tell you which one was actually responsible. If someone wants to bisect that and report back, it would be useful.
Where to put it
Depends on your bootloader. Note that these are module parameters for the xe driver, so they must be on the kernel command line at boot. There is no runtime toggle.
systemd-boot (what archinstall gives you by default): edit your entry under /boot/loader/entries/. The filename is date-stamped from install time, so mine is 2025-02-09_06-02-29_linux.conf. Append to the existing options line, do not add a second one:
options cryptdevice=PARTUUID=<yours>:root root=/dev/mapper/root rw rootfstype=ext4 xe.enable_psr=0 xe.enable_panel_replay=0
Do the same in your -fallback.conf entry. If you only patch the main entry, the fallback boot will tear and you will think the fix regressed.
GRUB: add to GRUB_CMDLINE_LINUX_DEFAULT in /etc/default/grub, then grub-mkconfig -o /boot/grub/grub.cfg.
Either way, confirm it took after reboot:
cat /proc/cmdline
You should see both parameters at the end.
What if you want the power saving back
PSR and Panel Replay exist to save battery by letting the panel hold its own framebuffer while content is static. Turning them off costs you some idle battery life. Before giving up on them entirely, worth trying:
xe.psr_safest_params=1
That keeps PSR on but replaces the VBT-supplied timing parameters with conservative ones. If that alone fixes it, the bug is bad values in the VBT rather than PSR itself, which is useful information for anyone filing upstream.
You can also try xe.enable_psr=1 (cap at PSR1, no PSR2) as a middle ground. I have not tested either of these myself, since the full disable solved it and I stopped there.
My exact config, for comparison
  • Framework Laptop 13 Pro (Intel Core Ultra Series 3), board FRANMJCP07 rev A7, Batch 1
  • BIOS: INSYDE 03.02, dated 2026-05-26
  • CPU: Intel Core Ultra X7 358H
  • GPU: Panther Lake, Arc B390, PCI ID 8086:b082 rev 04
  • Panel: BOE 0x095F, 2256x1504, eDP-1, glossy variant
  • Arch Linux, last full upgrade 2026-07-26
  • Kernel 7.1.5-arch1-1, mesa 26.1.5, linux-firmware 20260622, systemd 261.2
  • Wayland, Hyprland 0.56.0
  • Bootloader: systemd-boot 257.2, Secure Boot disabled
  • Root on LUKS (relevant only because it makes my kernel command line long, see the systemd-boot example below)
I run the panel at a manually set 48 Hz to save power (it supports 60). That is unrelated to the bug, but mentioning it so nobody reads a low refresh rate in my output as a symptom.
If you are on this hardware and reading this in a panic
Try the two parameters before you open a support ticket. If they fix it, you have a driver-side workaround and a working machine, and it is worth adding your panel model and BIOS version to this thread so we can see whether this is panel-lottery or universal to the Batch 1 config.
If they do not fix it, post your cat /proc/cmdline, your panel model from hyprctl monitors or drm_info, and your kernel version, and someone can help narrow it down.
Just a short follow-up here as I was running into the same on Fedora 44, kernel 7.1.5: xe.psr_safest_params=1 ended up being sufficient to solve this issue for now.
Coming from a Framework 13 upgraded to a Core Ultra Series 3 mainboard with the 2.2k matte display.
I’m experiencing the same issue. At first I thought I broke something, but it only occurs right after a login. And usually takes longer after a full reboot.
xe.psr_safest_params=1 didn’t work for me. xe.enable_psr=0 xe.enable_panel_replay=0 removed the flicker, but just made the screen black in the period it would normally flicker.
I’m running Arch Linux on the Framework 13 Pro Intel Core Ultra X7 358H
I’m seeing the same thing, I tried all suggested combinations and both xe.enable_psr=0 xe.enable_panel_replay=0 and xe.enable_psr=1 worked for me (sticking with the latter).
I’m running CachyOS on a Framework 13 Pro Intel Core Ultra X7 358H (Batch 10).
FWIW, In my setup the culprit ended up being the HDR support.
Ultra X7 358H running kernel 7.2.7 with GNOME 50.
I went down the rabbit hole, trying both with 6.18 and 7.2 kernels while going through combinations of xe.{enable_psr[01], psr_safest_param=1, enable_dc=0, enable_panel_replay=0, enable_fbc=0}
When HDR was enabled: with 6.18 kernel I had flickering. xe.enable_psr=0 solved it but at the expense of power savings. With 7.2 things got uglier. Without any kernel params, built-in display would be garbled the moment GDM logged me in (see below) or if switched to a tty (e.g. ctrl+alt+f3) and back to GNOME session, same result.
Finally dawned on me that desktop session is asking for something the card or eDP link or the display cannot do, that GDM or tty framebuffer isn’t. From there the only two options were HDR and variable refresh rate. But turning both off didn’t solve the issue. I’m not quite certain, but there’s likely a GNOME bug as well. ~/.config/monitors.xml file kept retaining <colormode>bt2100</colormode> line. As any rational person would do (/s), instead of editing it, I just moved it aside (i.e. mv ~/.config/monitors.xml{,.bak}) and manually re-did my config. Not touching either HDR or VRR. It was HDR. As I’m writing this, variable refresh rate of 30-120MHz is enabled again.
Now we can observe PSR2 is active.
~% run0 cat /sys/kernel/debug/dri/0/i915_edp_psr_status
Sink support: PSR = yes [0x03], Panel Replay = no, Panel Replay Selective Update = no, Panel Replay DSC support = not supported
PSR mode: PSR2 enabled
Source PSR/PanelReplay ctl: enabled [0x8000c399]
Source PSR/PanelReplay status: IDLE [0x04040030]
Busy frontbuffer bits: 0x00000000
Performance counter: 0
PSR2 selective fetch: enabled
Looks like the CSW MND508ZB1-1 panel does NOT support Panel Replay of any kind, or DSC for compression. I guess if we do the math, 2.8K @ 120Hz with SDR:
vertical = 2880 + 80 = 2960 (with vesa blanking)
horizontal = 1920 + 92 = 2012 (ditto)
pixels = 2960 x 2012 = 5,955,520
bits_per_pixel = 8 x 3 (8-bit RGB) = 24 bits
refresh rate = 120Hz
bw = pixels x bits_per_pixel x refresh_rate / 10^9 = 17.15 Gbps
…so eDP 1.5’s 25.92 Gbps is more than enough to drive this display without needing stream compression, hence they can get away without DSC support.
Sad display with HDR enabled:
Additionally if you don’t remove these from your cmdline they will prevent the kernel from using the xe gpu altogether in your new panther lake mainboard.
Me personally I’m hoping broadcom hurries up and fixes workstation pro to work with the new FRED on Panther Lake. For now you have to disable it as well in the cmdline.
I have the same problem on Fedora 44 + gnome.
Adding both xe.enable_psr=0 and xe.enable_panel_replay=0 solves it, on the cost of battery life.
➜ uname -r
7.2.8-200.fc44.x86_64
➜ cat /sys/class/dmi/id/bios_version
03.02
On that note, do we know if Framework has some kind of a gold image / template installation without turning off PSR? (Why does Arch need this turned off? What’s the cause here?) Given that the laptop has been heavily marketed towards Linux users, what’s the battery life one can expect when running Linux. Their battery test / demo only showed Windows runtime.
Turning off HDR for the built-in display allowed me to run with PSR2. No kernel command line parameters needed. Triedin both 6.18 or 7.2 with GNOME 50, see my reply above.
HDR for the external display can still be enabled. Problem seems to be relevant when the display is on eDP.
I am a bit worried to hear that even on Fedora. Since the FW13 Pro is marketed officially as supported and validated on Ubuntu and Fedora, while I ran into this issue on an older Framework 13, I didn’t expect that people would run into that on the Pro. Especially given the battery impact when disabling PSR. Isn’t this something that Framework would need to fix/provide support for?
True, with HDR disabled i have no problems atm.
Adding a data point from the AMD side: this is not Intel-specific.
Hardware: Framework 13 Pro, Ryzen AI 300 (Strix Point), 2.8K 120 Hz panel (CSW MND508ZB1-1), Arch Linux, kernel 7.2.11.
AMD equivalent of the workaround:
amdgpu.dcdebugmask=0x610
(disables PSR and Panel Replay in the amdgpu driver)
My case went further than flicker. After sitting idle on the lock screen for a few minutes, the internal panel went completely black: no image at any stage including BIOS, while the backlight stayed on and EDID still read fine. The state survived reboots and full shutdowns. The only thing that recovered it was disconnecting the display cable (fully cutting panel power). After reconnecting, I had the half-screen flicker described in this thread until I added the parameter above.
Kernel logs show zero errors through the whole event: the AUX link stays healthy, so the driver believes everything is fine. It looks like the panel’s TCON gets stuck in a self-refresh state it cannot exit without a power cut.
So the common denominator across xe and amdgpu appears to be the panel’s PSR/Panel Replay implementation. If your screen ever goes fully black and stays black across reboots, try disconnecting the display cable before assuming dead hardware, and consider disabling PSR before it happens.
Support ticket is open with Framework; I’ll report back if they acknowledge it as a panel issue.
I’ve had the same issue with my display, xe.enable_psr=0 was the only thing that fixed flicker when within the cosmic desktop.
Fullscreen video playback flickering was an additional issue (tested with Celluloid and VLC fullscreen) and setting xe.enable_fbc=0 and HDR off (by setting max_bpc: Some(8) manually in ~/.local/state/cosmic-comp/outputs.ron since cosmic doesn’t have a toggle) seems to have fixed it for now, but I have seen it come back on occasion after a resume…
Which Linux distro are you using? Fedora Cosmic Spin
Which release version? 44
If rolling release, last date updated? 2026-10-29
Which kernel are you using? 7.2.13-200.fc44
Is xe.enable_psr=1necessary to enable psr, when you use xe.enable_panel_replay=0 or can I just use the last?It seems to fix the problem for me, that my screen goes blank after resume from sleep. Using Ubuntu 26.04 with kernel 7.0.0-43.
I’m running Fedora 45 (KDE Plasma Edition) on my 13 Pro (received just a few days ago). Interestingly, the flickering started while I was watching a movie in mpv player. The reason why this is noteworthy is that the area flickering always matched the 16:9 area of the film playing on the taller 3:2 screen. This persisted after multiple reboots.
If I set xe.enable_psr=0, the flickering goes away on the desktop. It still seems to flicker when playing fullscreen videos, though. Is it possible that something is actually wrong with the panel hardware? It looks like the black bars on top and bottom of the video in mpv “fried” something in the panel’s own framebuffer.
What is pretty weird is that the same exact thing happened to the laptop I replaced with the Framework (ThinkPad P14s, on Fedora KDE). I was watching someting in mpv and it started flickering. I didn’t know about PSR back then and sent it back to Lenovo for a panel swap, which fixed the issue. Perhaps it’s just a very strange coincidence, but at this point I’m getting paranoid.
EDIT: The residual flickering on paused fullscreen video only seems to happen when I have adaptive sync set to “always” or “automatic” in the KDE system settings.
Here’s a quick recording of my FW13Pro on its default settings:
