Workaround: Framework 13 `Refused to change power state from D0 to D3hot`
Bazzite
Which release version?
43.20260313
Which kernel are you using?
6.17.7-ba28.fc43.x86_64
3.05
AMD Ryzen AI 300
New Framework 13 owner and user here; longtime Fedora + Bazzite user.
After setting up my OS, I was poking around in the journal and saw the following message getting spammed every second:
kernel: xhci_hcd 0000:c3:00.0: Refused to change power state from D0 to D3hot
I stumbled upon this journal message in another post here ( Kernel panics on Fedora 42 - 6.17.7 - #4 by James_Bond ) and the analysis done there.
My setup was similar to what was described there: USB-C adapter in the top left slot, USB-A adapter in the bottom left slot.
When I swapped the USB-A adapter for another USB-C adapter, the journal message stopped appearing.
Just wanted to confirm the workaround for anyone else seeing the error.
I used to had my ports configured in way where both left and right top ports where USB-C and both left and right bottom ports were USB-A and it worked well. But after latest BIOS upgrade I have left ports both USB-C and right ports both USB-A and I don’t see this error. Whenever I change ports config I’m getting mentioned error.
BIOS Revision: 4.2
I was wondering why the load on my system was > 1.6 permanently, even when the system was essentially idle.
After poking around for a bit, I also found the same error message. Switching the USB-A port from the left side with my USB-C port I had on the right, the warning disappears and the load reduces to a reasonable amount. Worth noting that this had a noticeable impact on the temperatures and battery as well.
Just hit this myself. I had the same setup a USB-C and a USB-A (from back to front) on each side. Was seeing these errors in dmesg output. Switching the 2 USB-C’s to the left side and the USB-As to the right side fixed the issue.
Debian 13 (stable) with Bios updated to 3.20 and just reset to defaults.
I’ve been fighting an issue with a flaky nvme/m2 drive cutting out from under me and was swapping out the drive for a new one when I noticed this. I’m not 100% it was doing this before I swapped out the new drive but I can’t see how the 2 are related. But mentioning it in case.
Adding more keywords to this, if anyone else is the same situation I was in:
Running NixOS 26.05, BIOS 3.05
Left side: USB-A card + HDMI card; Right side: 2 USB-C cards.
My HDMI card had been malfunctioning and would not pick up any displays. `xrandr` didn’t show anything other than the eDP display.
Running `dmesg` came up with the same message as this thread.
Swapping my USB-A for one of the USB-C cards solved the issue. Though I did also swap my HDMI card to be on the 1st slot (closer to the screen).
Chiming in to say “also been seeing this.”..
Also, you probably know, but raising for others, as I always forgot until I added a little sticker to remind me…
On the Ryzen 7040 series Framework 13, it’s the front-left slot (closest to you on the left side) that has no display output, so HDMI and DisplayPort cards won’t work there.
From Framework’s official diagram (Expansion Card Functionality on Framework Laptop 13 (AMD Ryzen 7040 Series)), with the laptop facing you as you’d use it:
  1. Slot 1 - Rear left - USB4 - Can Display Output
  2. Slot 2 - Front left - USB 3.2 - NO Display Output (JOSH, STOP FORGETTING!!!)
  3. Slot 3 - Rear right - USB4 - Can Display Output
  4. Slot 4 - Front right - USB 3.2 - Can Display Output
The numbering matches the photo in this thread, but be aware that photo shows the laptop upside down, so slots 1 and 2 on the right of the picture are actually on the left when the laptop is open in front of you. (I know this sounds like I’m stating the obvious, but I’m really bad spatially.).
Bonus musings: USB-A cards in the rear slots (1 and 3) draw noticeably more power because of the USB4 retimers, which can shorten standby time. If you use USB-A, put it in a front slot. Slot 2 is a good home for it since it can’t do display anyway, IMHO.
