Framework Laptop 16 (Batch 14) AMD Ryzen 9 7940HS with Radeon RX 7700S. Has been very lightly used for about a year. Most recently unplugged for a few months while I was away traveling. It started up fine with wall power; the battery was drained but it actually appeared to be charging OK. I left it on overnight (with lid open) to download a big file. The next morning, the screen was dark, lights were off, and it wouldn’t turn on no matter what I did.
I did open a support ticket, but I read reports of long delays in reply so I thought I’d ask for advice here in parallel.
I first re-plugged it in to wall power, the indicator LED initially was red/amber, and after several hours it became steady white (suggesting good charging). Meanwhile I was trying many things to troubleshoot. Reading the community forums and reddit I gleaned ideas including the following:
-Resetting the mainboard (holding the chassis intrusion switch down for 2 sec x 10 times, with the case open and the charger plugged in.
-Swapping/removing/rotating RAM sticks
-Removing all expansion cards except the one I was charging with (and that one I swapped left-right)
-Removing the battery, holding down power button for >30 seconds.
During this process I would occasionally get the following sequence of LED lights:
W-R-G-R-G-G-G-R-R-G-R-G-G-R-G-G-G-G-G-G-G-G
(Red lights correspond to: Battery connect check, Power Good VCCIN_AUX, Audio board Detect, Thermal sensor detected, CPU reached S0 state, if you go by the FW 13 chart)
However it would come on several minutes (2:04 on one of my videos) after a power-on attempt, never immediately after pressing the power button.
Sometimes, a power-on attempt would result in the white indicator light changing momentarily to red then blue once, or sometimes flicker blue first then red, before going back to white. Then for a while, unplugged, all LEDs are off and pressing power shows zero signs of life. When subsequently plugged in, the indicator LED is white, and pressing power seems to impact nothing whatsoever (no change in color). I then removed the keyboard and disconnected the mid-plate ribbon press-connector again, and the power button once again elicits a R-B or B-R color flash (seems random which order it occurs in, but it’s always just one flash of each color).
Differential diagnosis: Considering the battery - the charging light went from red to white after an appropriate amount of time which is somewhat reassuring. The red flashing light during POST corresponds to a bad battery connect check however. Yet, behavior is different if I fully disconnect the battery before power-on attempt (couldn’t get a POST with battery removed). I know lithium batteries are susceptible to damage from deep discharging, but I wouldn’t expect a failure to look like this– I dunno? I don’t think it’s RAM- I tried swapping/removing. I don’t think it’s interference from an expansion card- I removed all I could. I considered an ECU malfunction, but I hoped that resetting the board (many times) would clear it.
That leaves me with few theories besides a mainboard failure. I’m hoping the community has a few more reasonable tricks or tips to suggest, alternate theories, or interpretations that strongly suggest a specific diagnosis.
Thanks in advance!
