Test/Development Bench for Framework Motherboard
3D Printable Test/Development Bench for Framework Laptop Motherboard.
If you are working on a project with your Framework Motherboard. This 45 degree mount will make it easier to view and access both sides of your motherboard and all ports.
It also includes a mount for the stock wifi antenna module with cable routing underneath the motherboard.
