your computer wonāt be even able to run Win 10 Microsoft Solitaire Collection (microsoft store) at 60 fps
I run a Pentium 6405U Gold in a Hp ānetbookā crammed with $70ās worth of 16GB memory. I thought it was fine, but yesterday I tried to make a relatively simple CAD model (single solid, single part) and it just massively lagged it with like 1 fps of (basic rendering, not even rtx)
The point is outperform by how much, and can we expect that from Framework as well when comparing to the competition. (i.e. look beyond just the processor itself)
Ah. Yes they make very performant laptops that ā¦ somewhat lack chassis rigidity. Feels cheap, given the cooling solution they pack.
That prestige looks really nice, though.
I think itās thermal-limited. Those new chips are hot.
There isnāt a lot of info on the internals (general layout, etc) but it seems like they have at least 45W of cooling. A slightly more ābeefed-upā version of the current thermal solution should be adequate. Slightly thicker heatpipes and a thicker radiator.
The new XPS 13 plus full-send the thermal solution, going as far as to remove the function keys to get the extra 2mm of radiator height. LTT.
I am not going to say āconcernā, since itās kind of what that made it possible for them to be competitive (in terms of pricing) in a aggressively-priced market such as China, where other manufacturers are able to get away with using low-quality components (for the ram, storage, motherboard construction, etc.)
Because people donāt care about motherboard trace optimizations or what is the color of the sticker on the SSD or RAM. All they care is āthey both have a i7 and 3070 Ti, and this one is cheaper so I will go buy thisā, even though cheaper doesnāt always mean good, and usually means compromise in one way or another.
I was referring to their conduct towards reviewers, as linked in the video. (New paragraph, not a continuation of the same āaspectā of build quality)
Hm. so they are actually building cheap machines and attempt to get away with by āpersuadingā reviewers to leave good comments
Isnāt MSI Taiwan?
In either case. They didnāt even bother to put a āabout usā tab on their website.
Wow. Thatās a letdown. I thought they had actual stuff to offer.
yo quiero una laptop modular de verdad, me gustarĆa una que pueda cambiar la bateria, ponerle refrigeraciĆ³n liquida, que coja 2 procesadores (el ryzen 9 7980hx y el i9 12900hx) bluetooth 5.0 ha eso le llamo una laptop modular.
I want a real modular laptop, I would like one that can change the battery, put liquid cooling on it, that takes 2 processors (the ryzen 9 7980hx and the i9 12900hx) bluetooth 5.0 has that I call it a modular laptop
Once again, people donāt understand how the laws of physics and thermodynamics work. Sigh.
This will never be possible, because what youāre describing is a PC that doesnāt exist. Not to mention your ābatteryā would be the size of a large briefcase and would weigh in excess of 70 lbs, and it would probably only last 30 minutes, tops.
haha yes I exaggerated a bit with the 2 processor but everything I asked for does not violate any physical law, look at my idea for example a pure lithium cathode battery stores 9 times more than a lithium ion battery with iron or something else.
the cooling is easily solved when the turbo mode is activated you have to be connected to the current with hydrogen circulating the processor (which has a very high specific heat) and the hydrogen cooled by a pertiel cell and the cell by external dicipators reinforced with water to cool it by convention, the only thing to wait for next year for ryzen 7000, Iām not an idiot or stupid.
I already have all the design in my mind, the only thing is to find a company to get to work and make it possible to use audio acoustic plugins with latency of nanoseconds
ha se me olvidava lo del peso con grafeno y los 5nm de tsmc se soluciona el tamaƱo y peso
With that comes a whole other problem. 12th gen has been out already for a while now. Some 2022 laptops have been shipping with it since January, more are coming out and available as we speak.
The later the framework (or any other company) releases their new products the less relevant they will be. Imagine if they would come out with the 11th gen now, nobody would care.
Thus, IF there will be 12th gen or AMD 6000 in Framework, releasing it 6 months from now would be rather pointless, as by then people will be waiting for next generations from AMD and/or Intel.
Given that framework donāt need to redesign all the rest of the laptop, it should be actually faster to the market than other brands.
Itās not like other companies canāt do the same. The Dell XPS13 laptop has used the same shell more or less for multiple mainboard iterations IIRC and minor changes like where to machine holes for the available ports arenāt a big deal either, especially not for larger brands.
itās not very difficult to design a somewhat portable ā¦ thing. that can provide ample cooling for the parts.
No. Only very specific server processors (Intel Xeon, AMD threadripper) support multi-core (with matching model numbers) systems, let alone having them two work together.
In the future, we might have so-called āhybid chipsā because we have UCIe.
The Dell XPS 9343/9350/9360 even have more or less the same motherboard. All of their parts (display, keyboard, battery, etc) are interchangeable and the chassis is the same. The only difference in that the 9343 donāt have Thunderbolt support.
Then you have the 9365 which lasted one generation, then the 9300 (which might be the one used until the new XPS 13 plus)
The 9360 is the last XPS I considers āgoodā because it have USB-A ports.
Yes. Fortunately, all signs (motherboard discounts) point to the fact that they are getting close(r).
