When trying to turn on the laptop it didn’t respond to presses at all. I made sure it was charged, then I opened it and checked the battery connection including reseating it. When I reconnected the battery i noticed that the side LEDs flashed red three times. Didn’t notice that before if it was happening. Then noticed it when I’d press the power button.
The ribbon cable for the keyboard appears to be connected on both sides. The battery cable does appear to sit at an angle in the connector, but I noticed that when I originally assembled it. I’m not able to get it to sit any better in the laptop.
Running pop os. Don’t know the bios; can’t turn it on to check. Not sure what else y’all may need to know to assist with troubleshooting.
