Hello,
I’ve been having intermittent issues with my 12th gen 1260p Framework laptop on Windows 11. In particular, the fingerprint reader gets disabled after going to sleep mode. Not always, but quite often. The only way to re-enable it is to disable the device in Device Manager and then re-enable it. It does this more often when connected to AC power, and a less frequently when on battery.
Also, I sometimes get an error message that a USB device has malfunctioned. It usually cures itself after a few power cycles and does not seem to affect any of the functions, but still very annoying.
To give credit, I did contact support and we ended up doing the deep battery reset which cured the issues for a few days. But then they were back.
Anyone facing something similar? It doesn’t seem to be a software issue per se, more like a grounding issue, but I’m not electrical engineer.
