60w Power Adapter is out of Stock. Recommended alternative?
Happy Framework user. The Framework Pro 13 is my first from Framework and its awesome. I’d like a second power adapter but the 60W is out of stock.
What is the recommendation for a secondary traveling one? Will any Anker USB-C power adapter do?
Look for a few things:
  1. Examine the actual USB Power Delivery specs carefully (voltage and amps).
  2. Definitely only buy UL-listed (or the equivalent European or Chinese or whatever certifying body) chargers.
  3. The smaller the charger is, the more corners they had to cut on the circuitry or cooling to make it small/compact. I have found that the chargers with the least noise, best surge suppression, and highest fire safety tend to be the biggest/heaviest units, such as the heavy Apple or Lenovo chargers that they ship with their nicer laptops.
Anker is okay; I would not use one myself but don’t warn my users not to use them.
If I were you, I’d go up to the next-lowest wattage Framework charger, even though it is bulky and more expensive. At least we know it will be trustworthy (won’t fry your Framework laptop, won’t start a fire). Put the bulky one you buy next at your desk and take the 60W you already own as your travel charger.
Apple’s latest GaN 70W USB-C adapter is superb.
Extremely in-depth review: https://www.youtube.com/watch?v=lTLB6QwzLq4
Based on the teardown ( https://www.youtube.com/watch?v=lYfoRkzqAII ), it looks like it is quite well engineered and will probably outlast all the laptops you will ever use that have USB-C.
I’ll just say one thing. Power adapter is one of the very few places where I would NOT compromise on price. Paying premium for a reputable brand is not always bad.
Hey! The 60W is only temporarily OOS in some regions. If you are able to wait a short time, it’ll be back soon!
It sounds like between @dchang and @Eagle I’ll wait for the restock and not be afraid of getting the slightly larger one to keep at home. Thank you folks!
I use an Anker 735 Nano II 65W charger plug & Anker 240W Zolo USB C to C cable for charging when I’m away from home.
I do have the Framework 60W charger for at home charging.
I’ve been using GaN chargers from UGreen for a very long time now, and have had no issues. Also used Anker in the past. I trust both of those brands to be honest.
For travel (not the smallest, not the best…but ‘good’):
Or go big and get the 180w or 240w charger! Then take the 60w one with you. The 100W newer model Framework has looks promising.
how long is a short time? It’s still OOS here in the US 12 days later. same with the 100W and 180W
I cant give you an exact answer… but we recently had a Typhoon hit in Taiwan which is where most of our shipments come from. Restocks in local warehouses may be delayed a bit while they recover.
I’d imagine Lenovo chargers would work extremely well - especially their docks if that’s you.
The ikea one is pretty big for a 65W but it is available everywhere, cheap, guaranteed tested and certified for wherever you buy it and works well so pretty good generic recommendation.
