Ubuntu 24.04 LTS
Which release version?
24.04
Which kernel are you using?
16.14.02.29-generic
firmware 03.04
AMD Ryzen™ AI 300 Series
Screen Zoom shortcut does not work, except for zoom whole screen (even when that is disabled in the zoom settings). The keyboard settings are alt super +/- to get the magnifier.
Most shortcuts work: cut and paste, in the terminal and otherwise. I installed gpaste (and gnome tweaks) and those (new) shortcuts work.
This is probably an Ubuntu/ wayland problem but I thought I would check here.
Is this a shortcut problem or a zoom problem? Is there a way to tell if the (not full screen) magnifier isn’t working? Full screen magnifier works! (Alt super 8)
