ADATA CT16G56C46S5 Compatibility, Or how to generally identify if RAM is compatible?
Hello!
Does anyone know if the ADATA CT16G56C46S5 is compatible with the AMD FW13?
Or is there a general way to tell if a RAM kit is compatible?
Thanks!
Below is a list of supported RAM sticks. Although memory with the correct timings should just work. It’s just not guaranteed. Make sure you look at JEDEC timings and not XMP. AMD does not support XMP.
It looks like the timings on your RAM stick are correct.
More info:
