AMD Radeon RX 7700S idle power consumption
Does anyone have any guess as to how much more power the AMD Radeon RX 7700S expansion module uses at idle compared to the expansion bay shell?
I don’t have much of a need for a dedicated GPU, but it would be nice to have it when needed, I’m just wondering if the idle power usage difference is enough to justify powering down the system and switching out the modules, or just keep the GPU module in.
I’m not sure about the idle consumption of the 7700S, however theoretically it shouldn’t matter because the system is supposed to automatically deactivate the dGPU when at idle and just use the iGPU.
However in practice many users have reported (with other laptops) that poorly optimized software sometimes causes the os to keep the dGPU active. For example I’ve seen some people state that the Microsoft Phone app causes issues.
That’s why I created this thread few weeks ago: GPU expension bay: physical ON/OFF switch?
It might be an idea for the next gpu bay extensions ?
So it pulls around 100Watts (some reporting up to 115) from the early reporting and white papers! Which means it will be more efficient than the 3060 desktop, and a little under the 7600MTX mobile (20 watts lower).
But we don’t know what Framework will clock it at… estimates are that it will be stable at 75watts just fine, but maybe it can go even lower? Some older GPUs were stable all the way down into the 30s so…pbbbtbtbt shrug hard to say. Expect a 100watt draw, MAYBE up to 115watt, but framework could potentially underclock it maybe even down to 75watts which would be 5 watts under the 7600mXT give or take 5 for safety.
@Kody_Boen the poster is asking about the power consumption when under little to no load. You seem to be talking about the power consumption under load, which Framework has already indicated will be around 100w.
Ahh, then most GPUs are capable of 85% today, so 85% of 100. 85 watts… but also reports of it working at 75 watts, so it might be getting 75%. Eventually a GPU cannot be stable if underclocked too much, messes with memory timings etc. So as I said before, likely 75 watts.
Unless this GPU is more like older GPUs or more like APUs then it could potentially go all the way down to like a whopping 33% like the old days if it’s been designed specifically to run in extremely low wattage but still maintain stability. you can technically get even 4090’s or 7900 XTXs down to 30-33% of their maximum but it takes a lot of work and they tend to not be very stable. But again, it could be tuned specifically for it, so who knows. APUs can handle being extremely undervolted.
We’ll have to wait to see what Framework did with it. My bet, 75 watts. I’d put money on 55-60 watts, but I feel 75.
You might be a bit confused about underclocking vs. undervolting vs. power (watts) consumed at idle. See TechPowerUp – the 4090 can use up to 500 watts but still idle at 21 watts.
AMDs idle draw has been low for a while. I typically see 3.5W on a desktop RX6600, running at 3440x1440/100Hz.
The new gen laptop optimised stuff will be even lower.
I think you might be a bit confused.
A quick test shows that my desktop 3070 draws around 20w during light load (such as web browsing) despite consuming well over 200w when actually under load.
Although even 20w would be an atrocious idle power consumption for a GPU being used in a laptop. That alone would drain the battery at 24% per hour.
My current laptop (a Razer Blade 15 with RTX 3070) will let the 3070 draw about 15W sitting at the desktop without anything running. I have spent a lot of time and energy trying to get it to turn off and stop drawing power unnecessarily, but alas any fix I find or implement is only temporary.
Now I simply run Arch Linux and the is disconnected via software and cannot be used unless I remove the block and reboot.
AMD has idle power draw issues in multi-monitor configs.
With my 5700 xt the idle power draw issues with multi-monitor configs only occured if the monitors used non-standard timings. I was able to solve it by setting both of my monitors to use the standard Coordinated Video Timings.
What did you use to figure out what the dGPU was being used and how much power it was using?
There’s a linux tool called nvtop that gives some power data and it seems to be mostly right, but I got that figure by running the laptop idle at the desktop and getting the battery’s power draw from powertop, then disabling the gpu (rebooting) and then observing it again. There was a 15W delta, which was about consistent with what nvtop reported.
There are tools on windows that can do the same thing, like HWInfo 64.
I will note that the expansion bay modules don’t appear to be intended for regularly swapping out as it involves removing screws inside the chassis. There are also some community concerns about the number of times the port can be plugged/unplugged, but Framework doesn’t like us to speculate on those as they haven’t released an official port rating yet.
For my FW 16 I ordered it without the GPU because I’m sick of the work arounds it takes to disable it. I’ve got a desktop with GPU if I need it, and there’s always eGPU options.
