Anyone found a place to purchase the RTC battery for the AMD Framework 13?
after a year of issues
Sorry, We’ve tested to check out the battery again, but it’s still coming as out-of-stock or unavailable. However, below is the spec of the battery that we use. You might find plenty of these locally or online if you urgently need it.
ML1220 Rechargeable 3V CMOS RTC Battery for Laptops w 2pin cable (this is with the enclosure cable) Any brand will do (Maxell/Panasonic/KTC/ etc)
But i can confirm that even with a rtc battery the amd mob dosnt work in standlone mode
this may be due the 3 party battery but i have 3 board with the exact same issue
Please let me know if you are not able to order the battery (and what region are you in). Thank you!
