I have searched for what is essentially an empty plate or component, something flat, to take the place of the entire input cover on the Framework 13 without any success so far, so if this is a duplicate, feel free to merge this into any relevant topic. If not and someone else has done this, feel free to link to the relevant information.
My idea, which I plan to have someone help me with, who can see and who can 3D print, is to replace the input cover with what is essentially a flat plate. This would contain the necessary threaded inserts for the bottom cover to screw it in place. The goal would be to use a Framework 13 without any input cover at all, with or without a display and anything associated with the top cover. The WIFI antennas could be routed through this plate somehow. There would be a way to activate the power button, via a button aligning with the power button on the mainboard, or a small pin hole for an SIM card eject tool to prevent accidental presses.
Does anyone have any starting points or ideas on this? I’ve been unable to find precise dimensions for the input cover, though I have read somewhere that someone thought it was 3.8MM in height. If I can’t find these specs, I’ll let the one assisting me use the Framework 13 and its input cover to create the 3D print.
Once this is complete, I do plan to open source it, though someone else might want to host the GitHub repository so they can see, and review, any appropriate pull requests or issues. this is something I can’t do.
I, personally, could see a few useful purposes for this idea, and I’m a bit surprised I can’t find it. A quick means of setting up a headless server with the battery attached to act as a UPS. If someone didn’t want the bother of using Framework’s input cover for some reason, they could use it in this way without one. And, for me personally, since I need no display, I’ll just remove it and set a wireless keyboard right on top of the Framework itself if I can successfully create this blank input cover plate.
thoughts, ideas, considerations?
