Bluetooth connection failing for specific device [Laptop 13 (AMD Ryzen 7040Series) - Fedora 42]
I’m getting connection failures with Bluetooth headphones on Fedora 42 (installed fresh on a new Laptop 13 (AMD Ryzen 7040Series)).
dmesg shows this message twice each time I try to connect:
hci0: ACL packet for unknown connection handle 3837
I’ve confirmed I can connect to the headphones with other devices.
I’m also able to connect to other speakers from the Framework 13.
This is all the bluetooth output in dmesg. Could “Enhanced Setup Synchronous Connection” be an issue?
[ 5.088848] Bluetooth: Core ver 2.22
[ 5.088868] NET: Registered PF_BLUETOOTH protocol family
[ 5.088870] Bluetooth: HCI device and connection manager initialized
[ 5.088874] Bluetooth: HCI socket layer initialized
[ 5.088877] Bluetooth: L2CAP socket layer initialized
[ 5.088882] Bluetooth: SCO socket layer initialized
[ 5.367482] Bluetooth: hci0: HW/SW Version: 0x008a008a, Build Time: 20241106163512
[ 6.001889] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 6.001893] Bluetooth: BNEP filters: protocol multicast
[ 6.001898] Bluetooth: BNEP socket layer initialized
[ 7.617013] Bluetooth: hci0: Device setup in 2302397 usecs
[ 7.617021] Bluetooth: hci0: HCI Enhanced Setup Synchronous Connection command is advertised, but not supported.
[ 7.675379] Bluetooth: hci0: AOSP extensions version v1.00
[ 7.675387] Bluetooth: hci0: AOSP quality report is supported
[ 7.675592] Bluetooth: MGMT ver 1.23
[ 8.312821] Bluetooth: RFCOMM TTY layer initialized
[ 8.312832] Bluetooth: RFCOMM socket layer initialized
[ 8.312835] Bluetooth: RFCOMM ver 1.11
[ 39.773229] Bluetooth: hci0: ACL packet for unknown connection handle 3837
[ 40.118182] Bluetooth: hci0: ACL packet for unknown connection handle 3837
Any suggestions to debug this?
Thanks.
