I’m on Windows 11, with a latest-generation AMD Ryzen 7 13-inch model (acquired April 2024); 3.05 BIOS and the latest driver bundle.
Using the built-in Bluetooth, I’m able to pair Bluetooth keyboards — but the pairing gets dropped after a few seconds. I’ve tried with a couple of different keyboards and the result is the same. I set the keyboard to pairing mode, add it as a Bluetooth device, type the numeric code on the Bluetooth keyboard and hit enter, and pairing is successful — but it doesn’t stay paired for long, and I have to delete the keyboard, re-pair it (entering a new security code), and … then it drops the connection quickly again.
Anyone else have this problem? For the time being, I’ve disabled the built-in RZ616 Bluetooth adapter in the device manager and am using an external USB Bluetooth adapter instead — which works fine; the pairing holds. But obviously the internal adapter should work, too — and it doesn’t.
Many thanks!
Rob
