Hey everyone, just wanted to contribute my findings to this topic.
My specs:
- Framework Laptop 13
- AMD Ryzen 5 7640U
- Memory: 2 TB WD SSD purchased from Framework.
- RAM: 32 GB DDR5, also purchased from Framework.
- BIOS: 3.6
- Drivers: 9-8-2025 drivers
- Windows 11 Home Version 25H2
I upgraded from my old Framework 13 in January. I basically replaced everything but the shell; so I upgraded the motherboard, RAM, SSD, and I put a new matte screen on it. The keyboard, shell, fingerprint reader, etc… are all from my original Framework 13 that I purchased in 2021.
Everything ran generally stable and painlessly. However, every so often, the computer would hitch and freeze. I noticed this in particular in two contexts: one was when using the fingerprint reader, and the would be a few seconds/minutes after log-in.
These incidents were, however, pretty rare, so I never really gave it much mind.
About three or four weeks ago, I had a period of repeated crashing. The computer would only remain stable after log-in for about 30 seconds - 2 minutes before crashing into BSOD with the error code “Critical Process Died”. It would not collect any info or generate a report and would just crash to restart at 0%.
It did this about three times in a row before booting to the BitLocker blue screen and asking for my recovery key. I put the recovery key in and got back into the system. Confusingly, I was now able to log-in and use the computer without issue.
Flashforward to yesterday. I went to use my laptop and it kept crashing. No matter what I did, it would crash 10 seconds - 2 minutes after log-in. I was sent to the BitLocker screen after a handful of repeated crashes, I’d put in the recovery key, try to log back into Windows, then it would crash again with the same error code and 0% progress.
Eventually, after one of these cases where I had to put in a BitLocker key, Windows attempted to diagnose the issue, but couldn’t connect to the network so it never really managed to help here at all.
I found this thread and read through it, before finding Long_Pham’s suggestion to bypass the fingerprint reader. Even when I opted to log-in with my pin, it would crash the exact same way.
I decided step one for trying to fix this then for me was to do a fresh Windows install, which I did. After the fresh install I was able to log-in without issue, use the computer, download the programs I like to use and sync the files I need on the computer. Got it basically up and running completely fine.
I never turned on the fingerprint reader, and have left it disabled in setting. I now only log-in with my pin as I suspected the fingerprint reader was somehow at fault here.
My suspicions were confirmed when I went to download the office suite, and Microsoft attempted to log me into my account. For whatever reason, rather than asking for my password, Microsoft attempted to turn on the fingerprint reader to verify who I was.
And, viola, the system crashed immediately with the Critical Process Died error message and 0% progress just like it did before.
Now that I’m just using my pin, the computer works fine. If it attempts anything with the fingerprint scanner, it crashes.
I don’t know if what I am experiencing is the exact same problem you are, but I am going to post here that for me the fingerprint scanner seems to be the culprit. I don’t know if Framework’s drivers got messed up by a recent Windows update or what, but I don’t seem to be the only person having this issue and it’s something Framework should look into. Not having the fingerprint scanner is honestly not a huge deal for me, but I don’t like the idea of anything that attempts to use it instantly crashing my PC.
This might finally be my excuse to use Linux, but hey, I’ve got Windows working again, so maybe I’ll put that off to another time…
