Can I stick magnets on my midplate?
I suspect this might be a really silly idea, but would it risk any damage to the laptop if I tried to use magnets to track the locations of the screws that I have found and untightened?
I’m a blind user.
Some of the screws don’t sit proud once untighten so I’m likely to stumble over the same ones over and over.
Just make sure you get all the magnets out when you’re finished. If you miss one and turn it on, there are two components which would be affected by magnets:
  1. The fan. The motor probably would not like a magnet near it, and the fan itself has such tight clearances to its housing that it might drag.
  2. There’s a magnetic switch that detects if the screen is closed. It will shut down the laptop (as if the screen was closed) if there’s a magnet close enough to it.
Other than that, great idea, have at it!
I think that on the Framework Laptop 16 that is actually above the keyboard, not on the left.
Thank you for the correction, my apologies. Edited.
