Caps lock key light not working
Which Linux distro are you using? ArchLinux (Omarchy)
Which release version? rolling release without a release version
Which kernel are you using? 6.15.9-arch1-1
Which BIOS version are you using? 03.03
Which Framework Laptop 13 model are you using? AMD Ryzen™ AI 300 Series
Issue:
The caps lock key, when pressed does not display the light on the key indicating that caps lock is enabled.
Can anyone help me understand how to fix this issue?
Thank you,
Chris
Hello! Sorry to hear you’re having an issue with your caps lock key light. If you are still having the issue, please give our support team a contact. They’ll be happy to help you out!
Okay, thank you
