Framework 13 Capslock LED doesn't work
Arch
Which release version?
Which kernel are you using?
Linux arch 6.12.8-arch1-1 #1 SMP PREEMPT_DYNAMIC Thu, 02 Jan 2025 22:52:26 +0000 x86_64 GNU/Linux
Not sure
Which Framework Laptop 13 model are you using? (AMD Ryzen™ 7040 Series, Intel® Core™ Ultra Series 1, 13th Gen Intel® Core™ , 12th Gen Intel® Core™, 11th Gen Intel® Core™)
Capslock light doesn’t work, when I press the button it toggles uppercase / lowercase text, so button itself is working, and is mapped correctly, but light doesn’t go on, always off.
