Occasionally some keys wouldn’t register (so far I’ve noticed it’s T, Y, and O keys that stops working) unless I press down on T key hard enough to get it registering again and that fixes other keys too, if I press down hard on other affected keys, that doesn’t solve it, it seems to be T key only that gets it sorted out.
This is on a Framework Laptop 16, with RGB keyboard, I’ve took off the input/keyboard cover and reseated the cable but that doesn’t solve it, only pressing down hard enough on T key gets it working again for a while, I’ve noticed that when it happens, it’s usually on system boot up and wake up, and when I fix it, often remains that way until I shut it down/put it in sleep and pick it up the next day, and it happens all over again.
I’m running Fedora 42 Workstation Edition on it, but I suspect it’s a hardware issue more than a software issue.
