Not an issue in the tradional sense, more of a quality or materials review. I have three framework chargers and all three cables have started to split their sheathing in the same place. Two of these cables live pretty staticly attached to docks at work and home while the third normally stays in my car as the one I travel with. Chargers and cables still work great and to be clear I don’t need or want any kind of replacement. I can patch them with some shrink wrap lickety-split (soon as I stop procrastinating). Just wanted to provide some feedback and hopefully we see a switch in sheathing material in the future.
It’s possible you got cables during the time that Framework was experiencing an issue with their supplier. If you’re happy to fix them yourself, go ahead, otherwise support will help you replace them. Hopefully Framework has resolved this issue though.
