Charging issue. Can only use right middle to charge laptop
Hello all,
I’m running into a new strange issue when using my 240W charger and my Framework 16.
To my knowledge, the Framework 16 should be able to charge at the max speed with the upper 4 USB-C ports. However, when using these 4 ports, the charging light does come on but only the right middle charges actually charges the device. Any ideas as to why this is happening? I don’t recall this happening before. Charger is fine.
OS: Dual boot (Windows and Fedora)
BIOS version: IFGP6.04.03
Which release?: This happens in both Operating systems
Which product?: Framework 16 (AMD 7940S) with AMD Radeon RX 7700S
All the best
Try booting into bios, and selecting battery disconnect with the ac disconnected. Save and it should power off. Wait a few minutes and then connect the ac again to power it back on.
