It sometimes happens that the CPU gets stuck in a sort of low power mode.
Running a large parallel compilation in that state nets me an average of about 1GHz on all cores and a battery power draw of just 25W. For reference, the power draw would typically go up to 70W or so under such load and I believe clocks would be in >3GHz but I’m not sure.
Single core clocks are harder to judge for me but they’re certainly weird and it feels slow.
For something slightly reproducible, 100% load on 1C nets 1.something GHz while in power-saver and power draw is also barely above idle while it will typically go up to 40-50W. (That itself isn’t ideal but that’s for another topic.)
Needless to say, this slows things down significantly. Using any other program while such a compilation is running feels extremely sluggish. Just typing this out I can feel the lag.
Again needless to say but the compilation is extremely slow too.
I don’t know how exactly this happens but this machine has been up for 5 days and I only just noticed it. When I put it to sleep yesterday it was behaving normally.
This has happened a few times before and I think I once got it to revert back to normal by some sequence of plugging in power and going into s2idle but I can’t reproduce that.
Have any of you experienced this too?
I suspect this is related to the EC. I see entries like this when poking around in ectool console:
[2554107.949400 Battery 39% (Display 37.1 %) / 1h:40 to empty]
[2554108.010200 DC BEST PERFORMANCE]
[2554108.011400 event set 0x0100000000000000]
[2554108.060700 PMF: SPL 40000mW, sPPT 48000mW, fPPT 58000mW, p3T 118000mW, ao_sppt 0mW]
Perhaps that tells something to someone.
One thing I should note is that I switch power profiles very frequently.
I made it go into power-saver whenever I don’t interact with the machine for 2s because the other power modes draw like a few watts more which is insane considering the thing is basically idle with just Firefox doing idle browser things in the background.
cc resident AMD expert @Mario_Limonciello
NixOS
Which release version?
5633bcff0c6162b9e4b5f1264264611e950c8ec7
Which kernel are you using?
6.6.53
Latest according to fupdmgr
Which Framework Laptop 16 model are you using? (AMD Ryzen™ 7040 Series)
AMD Ryzen 7 7840HS w/ Radeon 780M Graphics
