I have an issue where when I move my cursor a short distance and then click, the cursor often jumps back to the original position, even though my finger is not moving when I click. Also, the distance does not even have to be that short for this to happen. Has anyone else seen this issue in Framework laptops or other laptops? Do I just have a bad track pad? I can buy a replacement if I can know that’s the issue.
I have tried installing Framework drivers, reinstalling all mouse and trackpad drivers, disabling PS/2 mouse emulation in the bios, and updating Windows 10 among other things.
video:
https://drive.google.com/file/d/1S85Hjl720BRlJCEZBBpVCMV9iasrXVuN/view?usp=sharing
It should be noted that I removed the keyboard without knowing it was attached via a cable and I yanked it slightly. I checked the cable and the connection and did not see any damage. I don’t think this caused it because the trackpad works fine otherwise. Also, the trackpad was not registering some clicks (even before I yanked on the keyboard) though it’s not doing this anymore.
