I’m dealing with some pretty severe system hangs that have now evolved into a total boot failure. It started over the weekend with a few hangs, two during heavy loads and one at idle. After the second reboot, I got stuck at the LUKS decryption step. Checking the systemd logs (via Esc) showed the below:
CPU#5 Utilization every 4000ms during lockup:
#1: 100% system, 0% softirq, 0% hardirq, 0% idle
rcu: INFO: rcu_preempt self-detected stall on CPU
rcu: 23-....: (240005 ticks this GP) idle=....
I tried to boot a live ISO (Fedora 44 and Ubuntu LTS), but no luck getting those to work. The system just hangs after hitting “Install”.
As of today I can’t even get my main system to the point of allowing me to enter the LUKS key. It just freezes/hangs when I select which image of bluefin to boot.
Contacted support, but hoping there may be some answers from the community too.
