So i moved my framework 16 from the orginal chaissie to the officaly proived printable case for it and i am conmolety unable to get the dgpu to show any sings of life, no fan spinning, bios dosen’t show it fastfetch dosen’t show it, systemd nvidia services can’t find it and lspci dosen’t show it.
I’ve tried aplying a small amoubt of pressure on the interposer reseating it and cleaning the contacts and pads via micro fiber cloth and rubbing achole
Any help would be good
I’ve been there, and I’m currently writing a guide about standalone mode. There’s a switch right next to the interposer. If you look at the top 3D-printed case, you’ll notice a small pillar that presses this switch down when the case is installed. It seems the dGPU only works when that switch is being pressed. I’ve highlighted the approximate location of the switch in red. The easiest way to fix the issue is simply to put the top case on. Hope that helps.
thank you so much that fixxed it,
but now i am havign weird usb issues whewre 4 of the 6 ports jsut don’t work at all
and i keep getting this error spammed aton Apr 09 14:34:45 cachywork kernel: ucsi_acpi USBC000:00: unknown error 256
