Disable Lower Right-Click Area
Hey there! Newbie Framework user and also newbie Windows on laptop user.
I’m very accustomed to right-click only being tied to a two-finger click like on macOS or Linux. I can’t seem to find a way to disable the lower right-click area.
Is this possible in Windows with the Windows precision drivers Framework provides?
Hope you’re enjoying your new laptop. I believe you can achieve this by finding the setting under Bluetooth&Devices>Touchpad>Taps. I’ve attached a screenshot for reference. If you’re using Windows 10, I believe the option would be a similar spot in the settings menu but I’m unsure.
