A few thoughts about this issue as Framework support pointed to it in a discussion.
My framework laptop is creating unusable screen images during increased sunlight. The laptop/operating system is changing the colors to a reduced depth (appearance only - no details) and a low contrast where the system is placing white text on a nearly white background. This isn’t specific to a program and there are no significant customizations loaded. I can reproduce this failure by sitting in a bright room which induces the failure and covering up the Ambiant Light Sensor (ALS) and the problem magically goes away.
Would be happy to disable the ALS if it were directly exposed as a driver.
I recognize that isn’t a fix, but I need a functioning laptop.
The closest thing I could find is:
Device Manager > Computer > Sensors > HID Sensor Collection V2
Microsoft driver dated 2009.04.21 10.0.22000.1
Microsoft says the list of sensors that this supports is:
Accelerometer 3D, Ambient Light, Ambient Temperature, Atmospheric Pressure, Compass 3D, Device Orientation, Gyroscope 3D, Humidity, Inclinometer 3D, Presence, Proximity
Sensor HID class driver - Windows drivers | Microsoft Docs.
The laptop is the i7-1185G7 with Windows 11 21H2 22000.348
In the initial recommendations regarding this, the first two were already completed. Just a note that the description of #2 was wrong. Here are the two locations.
Settings > Display > Change Brightness Automatically (turn off)
Settings > Display > HDR > Play steaming HDR videos (turn off)
The third suggestion was specific to Intel Graphics Command Center which was discontinued and no longer available without moving to an old driver.
Here is the link to Intel’s announcement.
Discontinuation of the Intel® Graphics Control Panel from the...)
