I’ve noticed that when my laptop gets a tiny bit of direct sunlight (specifically in my case in a moving car for the past few hours) , the screen adjusts/changes it’s brightness. This is great and all, except it makes the screen quite a bit blown out. The light/white objects on screen can be a bit hard to make out.
I disabled automatic brightness changing in windows 10, but that doesn’t seem to change the screen’s behavior? I’ve identified the brightness sensor as the small light grey hole next to the camera (as when I cover it the screen goes back to normal)
Any suggestions?
