Display Port Adapter Inconsistent - Redacted
I’m trying to use the display port adapter to connect to an external monitor using one of the 3 video out compatible ports. Unfortunately, it doesn’t seem to want to connect consistently. I’ve gotten it to work once, and the monitor will wake as if it’s receiving a signal but then the video feed will never start. HDMI works without an issue. Has anyone had this problem?
I’m on Arch Linux with KDE Plasma 6 (wayland).
Update: I stumbled across another identical display port cable, and it appears the cable I was using might simply be bad. I’m going to give it some more testing.
I have just received a framework-laptop-16 with the base processor, no dgpu, and the display-port and HDMI extension ports… so hoping to connect to an external monitor. The documents say they should work on ports 1,2, 4, and 5. They work fine with my monito on 1, and 2, but not 4 or 5.
Anybody know why?
additional context:
  • installed ubuntu 24.04, it is running latest hwe kernel.
  • when I plug into the laptop the messages in /var/log/kern.log are identical except bus numbers.
e.g.
025-05-02T09:36:42.483270-04:00 idefix kernel: usb 7-1: new full-speed USB device number 3 using xhci_hcd
2025-05-02T09:36:42.647721-04:00 idefix kernel: usb 7-1: New USB device found, idVendor=32ac, idProduct=0003, bcdDevice= 0.00
2025-05-02T09:36:42.647748-04:00 idefix kernel: usb 7-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
2025-05-02T09:36:42.647750-04:00 idefix kernel: usb 7-1: Product: DisplayPort Expansion Card
2025-05-02T09:36:42.647752-04:00 idefix kernel: usb 7-1: Manufacturer: Framework
2025-05-02T09:36:42.647753-04:00 idefix kernel: usb 7-1: SerialNumber: 11AD1D00218040011A1C0B00
2025-05-02T09:36:42.739736-04:00 idefix kernel: hid-generic 0003:32AC:0003.000C: hiddev4,hidraw10: USB HID v1.11 Device [Framework DisplayPort Expansion Card] on usb-0000:c3:00.3-1/input1
2025-05-02T09:37:02.800725-04:00 idefix kernel: usb 7-1: USB disconnect, device number 3
2025-05-02T09:37:19.015744-04:00 idefix kernel: ucsi_acpi USBC000:00: unknown error 256
2025-05-02T09:37:19.015767-04:00 idefix kernel: ucsi_acpi USBC000:00: GET_CABLE_PROPERTY failed (-5)
2025-05-02T09:37:19.315706-04:00 idefix kernel: usb 5-1: new full-speed USB device number 2 using xhci_hcd
2025-05-02T09:37:19.479722-04:00 idefix kernel: usb 5-1: New USB device found, idVendor=32ac, idProduct=0003, bcdDevice= 0.00
2025-05-02T09:37:19.479747-04:00 idefix kernel: usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
2025-05-02T09:37:19.479749-04:00 idefix kernel: usb 5-1: Product: DisplayPort Expansion Card
2025-05-02T09:37:19.479749-04:00 idefix kernel: usb 5-1: Manufacturer: Framework
2025-05-02T09:37:19.479751-04:00 idefix kernel: usb 5-1: SerialNumber: 11AD1D00218040011A1C0B00
2025-05-02T09:37:19.563721-04:00 idefix kernel: hid-generic 0003:32AC:0003.000D: hiddev4,hidraw10: USB HID v1.11 Device [Framework DisplayPort Expansion Card] on usb-0000:c3:00.4-1/input1
The above are the kern.log adaptors when inserted in right and left sides successively. Neither with a cable connected.
When I do connect a cable, the second one (usb5-1, on the left hand side, negotiates successfully. and I get an extended display on my 4K external screen.)
If I do the same into a the same extension card plugged on the right hand side of the laptop, I get a blank screen.
Display out on the Framework Laptop 16 is supported on expansion card slots 1, 2 and 4. There is no support for display on the right side, middle expansion card slot (5).
ah… so the only problemis slot 4 then…
