My display seems to have shadowing along both vertical edges. Is this expected?
To some extent…yes.
What you’re seeing is usually a result of display panel quality (chemical / electrical) and / or display mounting mechanism (pressure areas, mechanical).
Grey uniformity is a thing…and some panels are more uniformed than others…even when they’re of the same panel model.
In your case, especially the 2nd image, it seems like an assembly / mechanical related issue.
Thanks. How widespread is this amongst framework users? Something I should contact support about/return?
Think Framework support can guide you in this matter, regardless of the spread. My expereince with them have always been positive (sample size of 1, over around 4 different tickets).
