Anyone find the small holes on the vent panel are really bad with clogging with fine dust? Especially when running the dedicated GPU.
It always looks so horrible.
Anyone got any magic fixes?
(Yes we clean our house lol)
Magic fix, if you don’t have it on your lap and using an external screen, is to place it vertically, with something ike this: Amazon.fr
periodically just remove the vent screen. It is held down by the midplate so do same as you do to get at ram and storage, then remove the vent screen and clean. or you can remove the gpu expansion bay and blow it out from underneath. the vent screen is directly over the fans in the expansion bay so when remove there is nothing in the way from accessing the vents from below.
