Ubuntu
Which release version?
24.04
Which kernel are you using?
6.8.0-49-generic
03.05
Framework 13 Ryzen 7 7840U
-64GB Kingston Fury Impact 5600
-SK Hynix Platinum p41
Hi Guys
So I’ve not long had my framework 13. Great device.
The idea was to consolidate my devices. I had an hp elite book Ryzen 5 3500U, and a DIY built R7 3700X desktop with an RX5700XT GPU.
Simple enough plan, buy an eGPU enclosure and plug the RX 5700XT into it.
So I got a Lenovo Legion booststation 2nd hand (like the extra ports, networking and HDD bay) and when I plugged it into the laptop, the laptop started to charge… And nothing else.
boltctl monitor
Gives no output when plugging or unplugging the device. (I’m using the type c ports at the pack, i.e. closer to the hinge)
Tried 3 different cables, all tb3 cables, one of them IF certified 40Gbps, same story.
Booting up with the enclosure already connected, or waiting until it’s booted to plug it in, nothing. No change to lspci, lsusb or boltctl monitor. HDD installed in the enclosure doesn’t show up in disks.
Literally did nothing but make the ping noise because the charger was connected. In fact, if the laptop was already connected to a charger via one of the other ports, it didn’t even do that.
I tried running Windows 10 Pro on it
and that also, even after installing all the drivers and losing my fingerprint data (thanks for that windows), got absolutely nothing out of the enclosure but charging.
So I took the enclosure to my nearest branch of CeX (I bought online from them) and they couldn’t get it to work either so they refunded it. So I’m pretty sure the enclosure was dead. There are a few reports online about PSU failure on them so it’s not hugely surprising I guess.
So I ordered another one. Put in my GPU, turned it on, plugged it in, charging but no boltctl output.
So I think I’m probably just really unlucky and I’ve had 2 dead enclosures delivered.
Before I make the 20 mile drive to Merthyr Tydfil to dump this massive paperweight on their desk again, is there any eGPU setup step I’m missing??
I’ve watched a few different YouTube videos on using eGPUs on a framework and literally none of them go into any detail, they just say “I got 75fps in game X” or whatever and don’t go through the steps required to set anything up, and given that eGpus are a consumer product I expect it to be plug and play.
And yet in other places I see references to things like “of course I needed to add the missing firmware” or whatever with absolutely no detail or context.
For sanity I have 1 other TB3 device, and that’s a Samsung 34" ultra wide. The moment I plugged that in boltctl detected and auto-authorised it and my desktop displayed out on the monitor hence my expectation that a GPU enclosure would do something similar. Even if some jiggery pokery is needed to get display out of the enclosure device, I would expect the enclosure itself to be detected?
Assuming I’m doing it right and this device is also dead, I’m not going to bother with another Lenovo they’re clearly suffering from some design fault. Can anyone with a framework 13 AMD using an egpu with an AMD GPU recommend an affordable and working enclosure?
Thanks.
