Excessive power cycles and unsafe shutdowns reported by smartctl
Archlinux
Which release version?
October 16th, 2025
Which kernel are you using?
6.12.50-1-lts
3.07
Which Framework Laptop 16 model are you using?
AMD Ryzen 7040 Series
First SSD: WD BLACK SN770 1TB
Second SSD: WD BLACK SN770M 1TB
RAM: 2x 32GB Kingston Impact DDR5 5600
Over in the Laptop 13 forum I saw a discussion concerning smartctl reporting excessive power cycles and unsafe shutdowns. Out of curiosity, I ran smartctl (which I am too lazy to do regularly :zany_face:) and found interesting values:
First SSD (nvme0):
Power Cycles: 1.111
Power On Hours: 80
Unsafe Shutdowns: 26
Second SSD (nvme1):
Power Cycles: 111.251
Power On Hours: 144
Unsafe Shutdowns: 110.166
I did not observe any problems with the second SSD, suspend and hibernate also work as expected; but I think that such an amount of unsafe shutdowns cannot be very healthy over time.
I’ve always seen smartctl show high power cycle counts on SSD’s, going all the way back to my first SSD’s about 15 years ago. It’s the SSD counting power-save mode as low-enough activity that exiting power-save counts as a cycle. I’ve not seen it affect the durability of devices.
K3n.
