OS Windows 11 Pro 24H2
Laptop 13, 11th Gen Intel (R) Core ™ i5-1135G7 @ 240GHz
If there is no information pertaining to your issue or question, please let us know here: Framework | Support https://frame.work/support
I do not know whether there is any information pertaining to this issue so please forgive me. I have bounced around various links in this site, each pointing to the other, and cannot find any post that reports a problem quite like this one.
My expansion cards have ceased to be recognised in the Framework Laptop. It started with the USB Expansion SDD disappearing from the system, so I took it out and plugged it into the USB C socket on my PC and it works fine there. I ran chkdsk and disk manager on it, and it works perfectly. For a couple of days, it worked if I plugged into the USB A expansion card on the Framework, via a couple of adaptors.
Today, it is not recognised in any socket on the Framework. Neither is the SD explansion card. That one also works on the PC. I think all my expansion cards have become unrecognised on the Framework, but they all work on other hardware, even my Android phone. Therefore, I suspect a hardware problem in the Framework.
Maybe it is drivers? I update all the drivers just before this problem began to manifest. Is there a way of isolating the source of problem, please?
Best wishes
Will
