Feb 25 New AMD CPUs - Power Efficiency and Battery Life
So the day has finally come with the new AMD CPUs. Am I correct that technically the top end AI 9 HX 370 should have a similar battery life (when not pushed hard) as the bottom end AI 5 340 since they are both based on the same architecture and TDP generally?
Is it just that the AI 9 can be pushed hard for more intense multi-threaded and graphically intensive work when needed?
Battery life would really be my key deciding point.
yes thats generally how this works, if you run the same stuff on both CPUs they should have similar battery life but one of them has a higher top end speed when needed.
