Fixing a squeaky keyboard?
I have a 13th gen Framework 13, DIY edition. So far it has been great, apart from the space bar on the keyboard squeaking whenever it is used. Has anyone else encountered this or have any tips for fixing it? I’m more than happy taking the laptop apart again to get at the components, but as the keyboard is a single unit I’m not sure what options I actually have there.
(The topic template urges me to report that I’m running Debian Bookworm on the laptop, but I suspect that’s not relevant to the squeak…)
Welcome to the community.
It’s common for a spacebar to be slightly noisier than the rest of the keys, simply because it has more mechanisms inside. But I haven’t heard one squeak. Unless the key itself is rubbing against the case, then it’s likely one of the metal bars or scissor mechanisms inside. I’d guess the faintest application of something like dry silicone lube (something dielectric) would quiet it right down. Unfortunately, with the keycaps not designed to be removeable, I’m not sure how you’d manage to apply anything.
Some have reported successfully removing the keycaps, but others report damaging the key mechanisms when pulling the keycaps off. And I suppose the spacebar would be the most difficult to remove as well.
Sorry, I know I said a lot without really saying anything. The keyboard can technically be removed. At that point, you may be able to get in with something to lubricate the mechanism of the spacebar. It’s a lot of screws and you have to be careful not to strip any. Make sure you have a screwdriver that fits the screws really well if you are going to attempt it.
Mine was squeaky as well, and very annoying. I swapped it out with another one and the new one is great.
I didn’t end up doing anything to my keyboard and the squeak went away by itself after a while - maybe a month or two. I would have updated this thread sooner but I only realised it was gone after I saw this reply!
My 2nd gen input cover (Laptop 13, Nov. 2025) is starting to squeak all over. R, T, A, S, D, J, and L all have a little bit of crunch or squeak when I press on the bottom half of the key. It’s really annoying. The keyboard started out feeling really solid and quiet, until this started happening after a month or so.
On my unit, the up-arrow key is also too close to the aluminum frame and will rub if I push on the top half of it. Another quality control issue.
I received a replacement input cover (2nd Gen, FRANHV0001) from Framework for free after reaching out to support. The replacement keyboard doesn’t have the rubbing issue with the up-arrow key, and so far it doesn’t squeak. In a few months I will find out for sure if it is fixed.
After a few months the replacement input cover has the same issue. The Q, W, E, R, S, and D keys are all squeaky, same as the original input cover.
