I would clear CMOS, you do this by removing the charger disconnecting the battery, and remove the CMOS battery on the main board for at least thirty seconds. I am hover not framework support and accept no liability for any damage you cause.
/Zoe
edit to remove part not relevant to the solution, rest of my original post bellow:
You absolutely should get support from framework. it unacceptable that they don’t give appropriate support, assuming you are in a supported country with a device purchased directly from framework within warranty.
AFAIK the thing to reset the motherboard state should be equivalent to that, but I’ll try it - also, the 7040 series doesn’t have a CMOS battery, it just uses the main battery.
