Fedora 42
Which release version?
Which kernel are you using?
6.15.8-200.fc42.x86_64
BIOS Information
Vendor: INSYDE Corp.
Version: 03.04
Release Date: 06/10/2025
AI 300
I’ve been using the Framework 13 AI 300 laptop for the last couple of months, it is a really nice laptop. I’m having trouble with the bluetooth disappearing – it seems to me that this broke more recently. I had bluez v 5.83 installed (and this permanently broke bluetooth) and I read in the the forum that we need to downgrade back to v 5.80 which I did and after a reboot, the bluetooth was visible, however, now, after suspend/resume bluetooth is not visible again – I’m guessing if I reboot, it will fix itself.
How do I get bluetooth to work reliably?
Some pertinent dmesg messages
[ 0.000000] Kernel is locked down from EFI Secure Boot mode; see man kernel_lockdown.7
$ lsmod | grep blue
bluetooth 1089536 17 btrtl,btmtk,btintel,btbcm,bnep,btusb,rfcomm
rfkill 45056 8 bluetooth,cfg80211
