Hello, I’ve just bought a new Framework 13 (AMD Ryzen 7) laptop and built it myself, but I cannot reach the splash screen when I’m booting for the first time.
I’ve chosen to buy my own RAM and SSD in order to put in my laptop:
Crucial P3 Plus SSD (2 TB)
Kingston Fury 5600-40 Impact (2 x 32GB)
I’ve tried the following things in the following order:
I’ve shut down the laptop, disconnected it from the charger and tried booting it. Here, the display didn’t light up and the LEDs gave me the following error code: W G G G G G G G G G G G G O G B G B B G G G
After shutting down the laptop again, I shut down the laptop and reseated the RAM sticks, swapped their place with each other and reseated the SSD.
After booting the laptop again, I got the same error code
After rebooting the laptop, I do not get an error code anymore. Instead, the screen light ups, but nothing happens, even after 30 mins of leaving it on.
Now, I’ve kinda reached the point where I do not know what is going on, can somebody help me with this? Thank you ^^
Have you tried booting with a single stick of RAM? People have reported that booting with a single stick helps them successfully boot and following that, they can boot with 2 sticks of RAM.
I’ve just tried booting it with 1 stick of RAM placed in the DDR5 Channel 0 slot, but that also doesn’t work. When I tried booting it, I do get another POST error code:
I’ll try to disconnect the SSD this evening and see if it boots that way.
I would find it weird if the actual SSD or RAM is broken, I bought them new for this specific laptop. Is there a way to rule that out so that I can return them if that is the case?
Unfortunately, it’s difficult to rule out anything 100%, but if it boots without an SSD, at least you’ll have an idea that it’s either a bad drive or socket.
Either way, unless you manage to get it working fully, I would start a ticket with Framework and include details of the testing you’ve done and your results. Maybe link them to this thread as well.
