Framework 13 charger compatibility
Hi,
I wanted to get a Framework Laptop 13 the AMD one, but I wanted to save some money by using a charger that I have and always carry arround, which is this one → UGREEN Nexode Pro 65W
Is it going to work with the Framework 13 or should I buy the one included when you are going to purchase the Laptop?
Thanks for whoever will help me with this question!
Hi there!
I have had zero issues using other chargers on my Framework 13 using a 7840U CPU.
To date, I’ve used the following and they all work flawlessly.
Framework 60W Power Adapter
Lenovo 65W Power Adapter
Anker 736 Charger (Nano II 100W)
Asus ROG Gaming Charger Dock (65W)
ONEXGPU 100W passthrough power
Hope this helps! :slight_smile:
Hi and welcome to the forum.
The general idea is that the 13" is designed to take 60W so 65W is great.
And the other is PD compatibility
I want to add that I’ve also had zero issues using Leviton outlet as a charger as well.
Leviton T5636-W 60W USB Dual Type-C Power Delivery In-Wall Charger with 15A Outlet, USB Charger for Laptops, Smartphones, Tablets, and More, White - Amazon.com
Hi, guys.
Thanks for all the suggestion for other Chargers, but I prefer to have one and, if the one that I have works, it’s better for me.
Also I did check under suggestion of @amoun, if the charger that I have is PD compatible,
and I think it does have it.
So I think that clears out and it should work with the framework 13.
Again,
thanks to all of the guys who did responded!
